주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement
필요한 것
  1. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 1: 1 단계, 이미지 1개 중 1개
    • Remove the battery and memory card from the device.
    댓글 쓰기
  2. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 2: 2 단계, 이미지 1개 중 1개
    • Remove the single .5mm screw on the left side of the camera.
    댓글 쓰기
  3. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 3: 3 단계, 이미지 1개 중 1개
    • Remove 4 (0.5mm) screws from the right side of the camera.
    • There are two screws at the top.
    • There are two screws at the bottom.
    댓글 쓰기
  4. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 4: 4 단계, 이미지 1개 중 1개
    • Remove 5 screws from the base of the camera.
    • There are two (0.2mm) screws next to the battery compartment.
    • There are three (0.5mm) screws around the tripod base mount.
    댓글 쓰기
  5. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 5 단계, 이미지 1개 중 1개
    • Slowly open the back cover away from the device
    • The wrist strap bar can easily be lost so now is a good time to remove it.
    • Use caution. The rear cover is attached to the Main PCB via cables. You will need to release these cables before removing the rear cover.
    댓글 쓰기
  6. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 6 단계, 이미지 2개 중 1개 Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 6 단계, 이미지 2개 중 2개
    • Detach both ribbon cables using a spudger or other method.
    • Lift the black clip upward, unlocking the ribbon cable
    • Once the clip is in the up position you can slide the cable out. Release cable by pulling the cable out.
    • DO NOT pull on the Back case to release the cable.
    댓글 쓰기
  7. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 7 단계, 이미지 1개 중 1개
    • Screw Arrangements
    • Make sure you organize your screws to make re-assembly easier.
    댓글 쓰기
  8. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement, Step 8: 8 단계, 이미지 1개 중 1개
    • Remove the back casing from the camera.
    댓글 쓰기
  9. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 9 단계, 이미지 3개 중 1개 Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 9 단계, 이미지 3개 중 2개 Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 9 단계, 이미지 3개 중 3개
    • Use a spudger or other tool to release the 3 clips between the LCD case and housing.
    • Note: when re-assembly all 3 clips need to be seated in the grooves as shown in the 2nd picture.
    • Lift LCD out as shown in 3rd picture
    댓글 쓰기
  10. Panasonic Camera DMC-TZ3 LCD DISPLAY Replacement: 10 단계, 이미지 1개 중 1개
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sales Cameraparts4you
회원 가입일: 07/01/16
3,468 평판
안내서 22개를 작성함
3가이드 댓글
Very well presented and helpful - thank you.
It sems important to use the correct screwdriver and my impression is that the screws are JIS rather than Philips.
So far I have been unable to locate a replacement screen with back light (I assume the back light is connected by the narrower ribbon cable).
George Winspur - 답글 공유
I  Like my Panasonic  DMC-TZ3  , paid 300 way back in 2007  and has flawlessly  perfect, till I Dropped it in the case  …
IT still take pictures,  store on Memory, etc  all functions work , and can down load to computer ..
BUT the Back LCD  I can barely see unless I put a LIGHT to it ….
SO I assume I screwed the Back Light,  … can anybody help ?
Gary Trembley - 답글 공유
Hi…. the backlite cable might have come loose or damaged. I would disassembly the unit and re-insert the backlite cable to see if that does the trick.. Otherwise you would have to invest in a new Display ASSY or backlite. A used backlite or Display assy is not that expensive and easy to replace..
Sales Cameraparts4you - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 54
전체 시간: 4,789
