주요 콘텐츠로 건너뛰기
Panasonic ES2207P Motor Replacement
필요한 것
  1. Panasonic ES2207P Motor Replacement, Battery: 1 단계, 이미지 1/1
    • Remove foil head and blades.
  2. Panasonic ES2207P Motor Replacement: 2 단계, 이미지 1/1
    • Remove (2) 7.9mm Phillips #0 screws.
    • Remove (2) 14.3mm Phillips #0 screws.
  3. Panasonic ES2207P Motor Replacement: 3 단계, 이미지 1/1
    • Push the blade mount assembly towards the rear of razor and remove.
  4. Panasonic ES2207P Motor Replacement: 4 단계, 이미지 1/1
    • Be careful not to break any tabs that hold the panels to the body.
    • Remove both external panels using spudger if necessary.
  5. Panasonic ES2207P Motor Replacement: 5 단계, 이미지 1/1
  6. Panasonic ES2207P Motor Replacement: 6 단계, 이미지 1/1
    • This step may require a fair amount of force due to the O-ring.
    • Pull to separate the end-cap from the body.
  7. Panasonic ES2207P Motor Replacement: 7 단계, 이미지 1/1
    • Remove (2) 7.9mm Phillips #0 screws and remove endcap from frame.
  8. Panasonic ES2207P Motor Replacement: 8 단계, 이미지 1/2 Panasonic ES2207P Motor Replacement: 8 단계, 이미지 2/2
    • Push forward on the lower terminal to remove the battery from the frame.
  9. Panasonic ES2207P Motor Replacement, Motor: 9 단계, 이미지 1/2 Panasonic ES2207P Motor Replacement, Motor: 9 단계, 이미지 2/2
    • Remove battery contact.
  10. Panasonic ES2207P Motor Replacement: 10 단계, 이미지 1/1
    • Using pointed end of spudger, push on the motor through the hole in the back
  11. Panasonic ES2207P Motor Replacement: 11 단계, 이미지 1/1
    • Use your fingers to finish removing motor from frame.
결론
Kevin Marvell
회원 가입일: 11/06/17
309 평판
안내서 2개 작성하였습니다
IUPUI, Team S6-G5, Baechle Fall 2017 IUPUI, Team S6-G5, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S6G5
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 360
