주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Parrot Skycontroller 2 Power Port Replacement
필요한 것
    1. Parrot Skycontroller 2 Power Port  Replacement, Power Port: 1 단계, 이미지 3개 중 1개 Parrot Skycontroller 2 Power Port  Replacement, Power Port: 1 단계, 이미지 3개 중 2개 Parrot Skycontroller 2 Power Port  Replacement, Power Port: 1 단계, 이미지 3개 중 3개
      • Flip the controller upside down.
      댓글 쓰기
    2. Parrot Skycontroller 2 Power Port  Replacement: 2 단계, 이미지 1개 중 1개
      • Remove one 9mm screw using a #4 flathead screwdriver.
      댓글 쓰기
    3. Parrot Skycontroller 2 Power Port  Replacement: 3 단계, 이미지 3개 중 1개 Parrot Skycontroller 2 Power Port  Replacement: 3 단계, 이미지 3개 중 2개 Parrot Skycontroller 2 Power Port  Replacement: 3 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool into the top of the battery cover and pry upwards to lift the cover.
      • Remove the cover by pulling up and out.
      댓글 쓰기
    4. Parrot Skycontroller 2 Power Port  Replacement: 4 단계, 이미지 3개 중 1개 Parrot Skycontroller 2 Power Port  Replacement: 4 단계, 이미지 3개 중 2개 Parrot Skycontroller 2 Power Port  Replacement: 4 단계, 이미지 3개 중 3개
      • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
      • Disconnect the battery from the remote by pressing the white tab and pulling apart.
      댓글 쓰기
    5. Parrot Skycontroller 2 Power Port  Replacement: 5 단계, 이미지 2개 중 1개 Parrot Skycontroller 2 Power Port  Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the battery from it's brackets by pulling up gently on the ends of the battery.
      • Some force may be required to separate the battery from it's brackets.
      댓글 쓰기
    6. Parrot Skycontroller 2 Power Port  Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
      • There is a hidden screw located behind the sticker in the battery compartment.
      • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
      댓글 쓰기
    7. Parrot Skycontroller 2 Power Port  Replacement: 7 단계, 이미지 3개 중 1개 Parrot Skycontroller 2 Power Port  Replacement: 7 단계, 이미지 3개 중 2개 Parrot Skycontroller 2 Power Port  Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 Screwdriver.
      • The opposite side to the third picture has a screw located on each side of the USB port.
      댓글 쓰기
    8. Parrot Skycontroller 2 Power Port  Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the battery compartment plate by pulling up and out.
      댓글 쓰기
    9. Parrot Skycontroller 2 Power Port  Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the top plate by pushing on the corners with your hand.
      • Be careful to not pull too hard on the cable.
      댓글 쓰기
    10. Parrot Skycontroller 2 Power Port  Replacement: 10 단계, 이미지 3개 중 1개 Parrot Skycontroller 2 Power Port  Replacement: 10 단계, 이미지 3개 중 2개 Parrot Skycontroller 2 Power Port  Replacement: 10 단계, 이미지 3개 중 3개
      • Remove the face plate by pulling up and out.
      댓글 쓰기
    11. Parrot Skycontroller 2 Power Port  Replacement: 11 단계, 이미지 3개 중 1개 Parrot Skycontroller 2 Power Port  Replacement: 11 단계, 이미지 3개 중 2개 Parrot Skycontroller 2 Power Port  Replacement: 11 단계, 이미지 3개 중 3개
      • Make sure the controller is flat, then proceed to desolder the power port.
      • Desolder the four connection points surrounding the charging port.
      • Remove the power port from the controller.
      • For help with soldering best practices, check out our How to Solder and Desolder Connections guide.
      • Excessive heat can damage the power port, so do not apply the soldering iron to the component for too long.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 25
전체 시간: 871
