주요 콘텐츠로 건너뛰기
Penny Board Trucks Replacement
필요한 것
  1. Penny Board Trucks Replacement, Trucks: 1 단계, 이미지 2개 중 1개 Penny Board Trucks Replacement, Trucks: 1 단계, 이미지 2개 중 2개
    • Use a skate tool to loosen the bolt in the wheel with an appropriately sized socket.
    • A skate tool will come with all the tools necessary to do this replacement from start to finish.
  2. Penny Board Trucks Replacement: 2 단계, 이미지 2개 중 1개 Penny Board Trucks Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the wheel by lifting it from the truck.
    • Repeat this step for the other wheel.
  3. Penny Board Trucks Replacement: 3 단계, 이미지 2개 중 1개 Penny Board Trucks Replacement: 3 단계, 이미지 2개 중 2개
    • After completing the removal of both wheels, your board will look like this.
    • Place the skate tool over the bolt on the truck.
    • Maintain a good grip on the tool and use the Phillips screwdriver to loosen the nuts.
    • Repeat this step for all four screws.
  4. Penny Board Trucks Replacement: 4 단계, 이미지 2개 중 1개 Penny Board Trucks Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the truck to remove it.
  5. Penny Board Trucks Replacement: 5 단계, 이미지 2개 중 1개 Penny Board Trucks Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the screws from the board by pulling them out with your hands.
    • Use the Phillips screwdriver to loosen them more, if necessary.
결론
작성자
1다른 기여자 명과 함께
Eduardo Ron
회원 가입일: 02/17/21
171 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 19
전체 시간: 730
