주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pentax Super Program Front Block Functional Check
    1. Pentax Super Program Front Block Functional Check, Prepare the front block: 1 단계, 이미지 3개 중 1개 Pentax Super Program Front Block Functional Check, Prepare the front block: 1 단계, 이미지 3개 중 2개 Pentax Super Program Front Block Functional Check, Prepare the front block: 1 단계, 이미지 3개 중 3개
      • Connect a lead wire to the main flex PCB to supply battery power (early production).
      • Connect a lead wire to the main flex PCB to supply battery power (late production).
      • Make a ground connection to the body of the camera.
      댓글 쓰기
    2. Pentax Super Program Front Block Functional Check, Prepare the mode dial: 2 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Functional Check, Prepare the mode dial: 2 단계, 이미지 2개 중 2개
      • Ground the mode dial plate to the chassis of the front block.
      • Move the mode dial to the 'M' position.
      • Be careful not to let the ball bearing escape when passing through 'Auto' mode (the larger hole).
      댓글 쓰기
    3. Pentax Super Program Front Block Functional Check, Check power to the front block: 3 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Functional Check, Check power to the front block: 3 단계, 이미지 2개 중 2개
      • Use a source of 2.8 V to power the front block, the lowest battery voltage that the camera should operate at.
      • If an external power supply is not available, use fresh batteries to supply power.
      • Check the voltage at these locations to make sure that power is getting to all of the components.
      댓글 쓰기
    4. Pentax Super Program Front Block Functional Check, Check the main shutter release: 4 단계, 이미지 3개 중 1개 Pentax Super Program Front Block Functional Check, Check the main shutter release: 4 단계, 이미지 3개 중 2개 Pentax Super Program Front Block Functional Check, Check the main shutter release: 4 단계, 이미지 3개 중 3개
      • Charge the mirror mechanism.
      • Press the shutter button. The mirror should release and flip up into the taking position.
      • Push the mirror return latch to flip the mirror down into the viewing position (the shutter would trigger this mechanism when the camera is fully assembled).
      댓글 쓰기
    5. Pentax Super Program Front Block Functional Check, Check the self-timer: 5 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Functional Check, Check the self-timer: 5 단계, 이미지 2개 중 2개
      • Pull out the tab on the self-timer switch.
      • Press the shutter release button.
      • The self-timer led should blink and the buzzer should sound.
      • After ten seconds, the mirror should flip up.
      댓글 쓰기
    6. Pentax Super Program Front Block Functional Check, Check the motor drive shutter release: 6 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Functional Check, Check the motor drive shutter release: 6 단계, 이미지 2개 중 2개
      • Ground this pad to release the shutter (early production).
      • Ground this pad to release the shutter (late production).
      • This is the signal that the accessory motor drive uses to fire the shutter. It's also a useful alternative if you think there is an issue with the main shutter release.
      댓글 쓰기
      • Mount a lens on the front block. Set the aperture ring to 'A'.
      • Point the front block at scenes with varying brightness. Check that the aperture value in the viewfinder display changes accordingly.
      댓글 쓰기
    7. Pentax Super Program Front Block Functional Check, Check viewfinder backlight: 8 단계, 이미지 2개 중 1개 Pentax Super Program Front Block Functional Check, Check viewfinder backlight: 8 단계, 이미지 2개 중 2개
      • Cover the ambient light panel for the viewfinder displays.
      • Press viewfinder light button on the side of the lens mount.
      • The displays at the bottom of the viewfinder should light up.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
14,444 평판
안내서 78개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 26
전체 시간: 145
