주요 콘텐츠로 건너뛰기
Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement
August Post
August Post다른 한 명의 기여자
최종 수정일 July 15, 2024
10 분
조정
This guide will show how to take out both trimmer blades, and replace them with a new ones. You may need this if the trimmer blades on the Philips Norelco Bodygroom break, or for some reason become too dull to use. It is also necessary for this guide to show how to disassemble and reassemble the trimmer head in order to get to the blades. It is recommended to have the iFixit Pro Tech Toolkit since it will contain all tools necessary for this guide. Lastly, you will need to provide your own working blades to replace the broken ones.
필요한 것
도구
  • Spudger
    Spudger
  1. Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement, Trimmer Head Blades: 1 단계, 이미지 2개 중 1개 Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement, Trimmer Head Blades: 1 단계, 이미지 2개 중 2개
    • Pop open the trimmer head by pushing against the blades.
    • Slide off trimmer guard and open the hatch on the side.
    • Remove the trimmer from the base.
  2. Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement: 2 단계, 이미지 2개 중 1개 Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement: 2 단계, 이미지 2개 중 2개
    • Remove spring first, and then pull off white plastic along with the first, moving blade.
    • Use spudger to pry off second, stationary blade.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
August Post
회원 가입일: 11/07/17
415 평판
안내서 3개를 작성함
IUPUI, Team S2-G4, Harley Fall 2017 IUPUI, Team S2-G4, Harley Fall 2017 회원
IUPUI-HARLEY-F17S2G4
3 회원들
안내서 7개를 작성함
댓글 한 개
How do you reattach the spring?
Antonio Chrysokhou - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 38
전체 시간: 3,822
