주요 콘텐츠로 건너뛰기
Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement
Darren Chu
Darren Chu3 다른 기여자
최종 수정일 July 15, 2024
3 분
쉬움
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
In order to access the internal components of the beardtrimmer, the front and back panels must be removed. This guide will instruct you on the process.
필요한 것
도구
  1. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement, Front and Back Panels: 1 단계, 이미지 1개 중 1개
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 2 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 2 단계, 이미지 2개 중 2개
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 3 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 3 단계, 이미지 2개 중 2개
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 4 단계, 이미지 3개 중 1개 Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 4 단계, 이미지 3개 중 2개 Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 4 단계, 이미지 3개 중 3개
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 5 단계, 이미지 3개 중 1개 Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 5 단계, 이미지 3개 중 2개 Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 6 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 6 단계, 이미지 2개 중 2개
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 7 단계, 이미지 1개 중 1개
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 8 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: 8 단계, 이미지 2개 중 2개
결론
작성자
3다른 기여자 명과 함께
Darren Chu
회원 가입일: 09/03/15
1,617 평판
안내서 3개를 작성함
USF Tampa, Team 15-2, Blackwell Fall 2015 USF Tampa, Team 15-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S15G2
4 회원들
안내서 14개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 90
