주요 콘텐츠로 건너뛰기
Philips Norelco BeardTrimmer 3100 Handle Replacement
filmon gebregergis
filmon gebregergis3 다른 기여자
최종 수정일 July 15, 2024
6 분
쉬움
The following steps are a brief guide on how to replace the handle of the Philips Norelco beard trimmer 3100.
필요한 것
도구
  1. Philips Norelco BeardTrimmer 3100 Handle Replacement, Front and Back Panels: 1 단계, 이미지 1개 중 1개
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Handle Replacement: 2 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Handle Replacement: 2 단계, 이미지 2개 중 2개
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Handle Replacement: 3 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Handle Replacement: 3 단계, 이미지 2개 중 2개
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Handle Replacement: 4 단계, 이미지 3개 중 1개 Philips Norelco BeardTrimmer 3100 Handle Replacement: 4 단계, 이미지 3개 중 2개 Philips Norelco BeardTrimmer 3100 Handle Replacement: 4 단계, 이미지 3개 중 3개
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Handle Replacement: 5 단계, 이미지 3개 중 1개 Philips Norelco BeardTrimmer 3100 Handle Replacement: 5 단계, 이미지 3개 중 2개 Philips Norelco BeardTrimmer 3100 Handle Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Handle Replacement: 6 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Handle Replacement: 6 단계, 이미지 2개 중 2개
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Handle Replacement: 7 단계, 이미지 1개 중 1개
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Handle Replacement: 8 단계, 이미지 2개 중 1개 Philips Norelco BeardTrimmer 3100 Handle Replacement: 8 단계, 이미지 2개 중 2개
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
filmon gebregergis
회원 가입일: 09/03/15
143 평판
안내서 1개를 작성함
USF Tampa, Team 15-2, Blackwell Fall 2015 USF Tampa, Team 15-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S15G2
4 회원들
안내서 14개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 9
전체 시간: 5,738
