주요 콘텐츠로 건너뛰기
Philips Satinelle Metal Rolling Tracks Replacement
필요한 것
  1. Philips Satinelle Metal Rolling Tracks Replacement, Philips Satinelle Disassembly: 1 단계, 이미지 2개 중 1개 Philips Satinelle Metal Rolling Tracks Replacement, Philips Satinelle Disassembly: 1 단계, 이미지 2개 중 2개
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. Philips Satinelle Metal Rolling Tracks Replacement: 2 단계, 이미지 3개 중 1개 Philips Satinelle Metal Rolling Tracks Replacement: 2 단계, 이미지 3개 중 2개 Philips Satinelle Metal Rolling Tracks Replacement: 2 단계, 이미지 3개 중 3개
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. Philips Satinelle Metal Rolling Tracks Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • The left side will swing down.
    • Remove the Tweezers.
  4. Philips Satinelle Metal Rolling Tracks Replacement: 4 단계, 이미지 3개 중 1개 Philips Satinelle Metal Rolling Tracks Replacement: 4 단계, 이미지 3개 중 2개 Philips Satinelle Metal Rolling Tracks Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  5. Philips Satinelle Metal Rolling Tracks Replacement: 5 단계, 이미지 3개 중 1개 Philips Satinelle Metal Rolling Tracks Replacement: 5 단계, 이미지 3개 중 2개 Philips Satinelle Metal Rolling Tracks Replacement: 5 단계, 이미지 3개 중 3개
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  6. Philips Satinelle Metal Rolling Tracks Replacement: 6 단계, 이미지 3개 중 1개 Philips Satinelle Metal Rolling Tracks Replacement: 6 단계, 이미지 3개 중 2개 Philips Satinelle Metal Rolling Tracks Replacement: 6 단계, 이미지 3개 중 3개
    • Use a spudger to pry the gear housing unit from the base.
  7. Philips Satinelle Metal Rolling Tracks Replacement: 7 단계, 이미지 3개 중 1개 Philips Satinelle Metal Rolling Tracks Replacement: 7 단계, 이미지 3개 중 2개 Philips Satinelle Metal Rolling Tracks Replacement: 7 단계, 이미지 3개 중 3개
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
  8. Philips Satinelle Metal Rolling Tracks Replacement, Metal Rolling Tracks Replacement: 8 단계, 이미지 1개 중 1개
    • Replace Metal Roller Tracks on both sides of the Tweezer Head.
결론
작성자
4다른 기여자 명과 함께
Nathan Christian
회원 가입일: 11/11/17
505 평판
안내서 3개를 작성함
IUPUI, Team S5-G5, Wilson Fall 2017 IUPUI, Team S5-G5, Wilson Fall 2017 회원
IUPUI-WILSON-F17S5G5
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 8
전체 시간: 660
