주요 콘텐츠로 건너뛰기
Philips Satinelle Plastic Cover Replacement
Madeline Casalino
Madeline Casalino3 다른 기여자
최종 수정일 July 14, 2024
5 - 10 분
쉬움
Replace the epilator if the outer cover is so damaged that it becomes troublesome to hold. This is a very easy fix as it only requires you to transfer the components of the broken device into a new cover. You will need a metal spudger. Be careful not to damage any internal components as you pry apart the broken shell. This guide should take five to ten minutes to complete.
필요한 것
도구
  1. Philips Satinelle Plastic Cover Replacement, Plastic Cover: 1 단계, 이미지 3개 중 1개 Philips Satinelle Plastic Cover Replacement, Plastic Cover: 1 단계, 이미지 3개 중 2개 Philips Satinelle Plastic Cover Replacement, Plastic Cover: 1 단계, 이미지 3개 중 3개
    • Remove the head by pushing it to the right.
  2. Philips Satinelle Plastic Cover Replacement: 2 단계, 이미지 2개 중 1개 Philips Satinelle Plastic Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle Plastic Cover Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
결론
To reassemble your device, move the components from the broken shell into the new shell and follow these instructions in reverse order.
작성자
3다른 기여자 명과 함께
Madeline Casalino
회원 가입일: 10/08/18
313 평판
안내서 3개를 작성함
Marist, Team S1-G1, Chaterdon Fall 2018 Marist, Team S1-G1, Chaterdon Fall 2018 회원
MARS-CHATERDON-F18S1G1
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 630
