Philips Sonicare DiamondClean Metal Brush Connector Replacement
Use a Phillips screwdriver to remove the screw at the base of the metal head.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 8개
Great guide - but where is a good source for replacement parts?
Great post, thank-you. One question: My toothbrush has a wire loop around the head. The loop is soldered to the circuit board. Do you know what that wire is for? Cheers!
tim belina - 답글
