주요 콘텐츠로 건너뛰기
Philips razor shaving head replacement
Ernst
Ernst3 다른 기여자
최종 수정일 September 3, 2024
50 분
쉬움
커뮤니티-기여 안내서
더 나은 소개글
  1. Philips razor shaving head replacement, Shaver head: 1 단계, 이미지 1개 중 1개
    • Remove shaver head - clean it
  2. Philips razor shaving head replacement: 2 단계, 이미지 2개 중 1개 Philips razor shaving head replacement: 2 단계, 이미지 2개 중 2개
    • Use a small cell phone screwdriver to carefully pry off the lower cap on one side and pull it off over the other side. Then the shaving head can be removed completely.
  3. Philips razor shaving head replacement: 3 단계, 이미지 2개 중 1개 Philips razor shaving head replacement: 3 단계, 이미지 2개 중 2개
    • Then carefully push one side of the top black cap inward with the screwdriver and carefully pry it off the pin on one side. Then pull out the second side and remove the top.
  4. Philips razor shaving head replacement: 4 단계, 이미지 3개 중 1개 Philips razor shaving head replacement: 4 단계, 이미지 3개 중 2개 Philips razor shaving head replacement: 4 단계, 이미지 3개 중 3개
    • Then carefully lever out the metal ring (note top/bottom) by the two metal hooks and pull out the opposite side. Then carefully straighten the metal tab again to have enough tension when re-inserting.
  5. Philips razor shaving head replacement: 5 단계, 이미지 1개 중 1개
    • Then remove and replace the shaving head and thoroughly clean the rest.
  6. Philips razor shaving head replacement: 6 단계, 이미지 1개 중 1개
    • The assembly is done in reverse order. It should fit almost any older Philips shaver blade.
    • Short version: Insert the shaving head, insert the metal ring with one pin into a groove and press the second metal pin into the groove with the screwdriver. Then insert black head with one side into the recess of the silver metal holder and carefully press the opposite button into the second button by squeezing.
    • Then put the complete head right side up on the carrier and starting with the bottom on the head / pin !!! press the part back together. E voila a NEW shear head 🙋‍♂️
결론
Work through the steps in reverse order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
oldturkey03님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
3다른 기여자 명과 함께
Ernst
회원 가입일: 09/01/22
184 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 15
지난 30일: 46
전체 시간: 857
