PlayStation 2 Slimline SCPH-7500x Motherboard Replacement
This guide will walk you through step-by-step on how to properly remove and install the motherboard in the PlayStation 2 Slimline.
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
이 단계에 사용된 도구:Tweezers$4.99
Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
What you see in this picture is the electronic components found in the PS2. We are now going to remove the top metal casing found on top of the motherboard.
다른 13명이 해당 안내서를 완성하였습니다.
