주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation 4 Slim Fan System Replacement
필요한 것
  1. PlayStation 4 Slim Fan System Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 PlayStation 4 Slim Fan System Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 PlayStation 4 Slim Fan System Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
    댓글 쓰기
  2. PlayStation 4 Slim Fan System Replacement: 2 단계, 이미지 2개 중 1개 PlayStation 4 Slim Fan System Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew and remove the now exposed 5.0mm screw using a TR8 security Torx screwdriver with a counter-clockwise motion.
    댓글 쓰기
  3. PlayStation 4 Slim Fan System Replacement: 3 단계, 이미지 3개 중 1개 PlayStation 4 Slim Fan System Replacement: 3 단계, 이미지 3개 중 2개 PlayStation 4 Slim Fan System Replacement: 3 단계, 이미지 3개 중 3개
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
    댓글 쓰기
  4. PlayStation 4 Slim Fan System Replacement, Power Supply: 4 단계, 이미지 3개 중 1개 PlayStation 4 Slim Fan System Replacement, Power Supply: 4 단계, 이미지 3개 중 2개 PlayStation 4 Slim Fan System Replacement, Power Supply: 4 단계, 이미지 3개 중 3개
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
    댓글 쓰기
  5. PlayStation 4 Slim Fan System Replacement: 5 단계, 이미지 3개 중 1개 PlayStation 4 Slim Fan System Replacement: 5 단계, 이미지 3개 중 2개 PlayStation 4 Slim Fan System Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    댓글 쓰기
  6. PlayStation 4 Slim Fan System Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four 16mm Philips screws holding the power supply in place.
    댓글 쓰기
  7. PlayStation 4 Slim Fan System Replacement: 7 단계, 이미지 2개 중 1개 PlayStation 4 Slim Fan System Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
    댓글 쓰기
  8. PlayStation 4 Slim Fan System Replacement: 8 단계, 이미지 2개 중 1개 PlayStation 4 Slim Fan System Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
    댓글 쓰기
  9. PlayStation 4 Slim Fan System Replacement: 9 단계, 이미지 2개 중 1개 PlayStation 4 Slim Fan System Replacement: 9 단계, 이미지 2개 중 2개
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion. This screw holds the power supply in place
    댓글 쓰기
  10. PlayStation 4 Slim Fan System Replacement: 10 단계, 이미지 3개 중 1개 PlayStation 4 Slim Fan System Replacement: 10 단계, 이미지 3개 중 2개 PlayStation 4 Slim Fan System Replacement: 10 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
    댓글 쓰기
  11. PlayStation 4 Slim Fan System Replacement: 11 단계, 이미지 3개 중 1개 PlayStation 4 Slim Fan System Replacement: 11 단계, 이미지 3개 중 2개 PlayStation 4 Slim Fan System Replacement: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
    댓글 쓰기
  12. PlayStation 4 Slim Fan System Replacement, Motherboard: 12 단계, 이미지 2개 중 1개 PlayStation 4 Slim Fan System Replacement, Motherboard: 12 단계, 이미지 2개 중 2개
    • Unscrew and remove the 31.0mm safety screw using a T8 screwdriver with a counter-clockwise motion.
    댓글 쓰기
  13. PlayStation 4 Slim Fan System Replacement: 13 단계, 이미지 2개 중 1개 PlayStation 4 Slim Fan System Replacement: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the two wires connected to the bottom of the motherboard.
    • Remove the wires by firmly grasping the metal connections with your fingers or tweezers and pulling up until they disconnect.
    댓글 쓰기
  14. PlayStation 4 Slim Fan System Replacement: 14 단계, 이미지 3개 중 1개 PlayStation 4 Slim Fan System Replacement: 14 단계, 이미지 3개 중 2개 PlayStation 4 Slim Fan System Replacement: 14 단계, 이미지 3개 중 3개
    • Flip the device to the backside.
    • Unscrew and remove 14x (19x for CUH-21xx) 4.0mm black screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove 8x (7x for CUH-21xx) 6.0mm silver screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove 4x 3.0mm silver screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    댓글 쓰기
  15. PlayStation 4 Slim Fan System Replacement: 15 단계, 이미지 2개 중 1개 PlayStation 4 Slim Fan System Replacement: 15 단계, 이미지 2개 중 2개
    • Unscrew and remove the two 5.0mm screws on the side of the console using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Skip this step for the CUH-21xx, as those screws were removed in the previous step.
    댓글 쓰기
  16. PlayStation 4 Slim Fan System Replacement: 16 단계, 이미지 3개 중 1개 PlayStation 4 Slim Fan System Replacement: 16 단계, 이미지 3개 중 2개 PlayStation 4 Slim Fan System Replacement: 16 단계, 이미지 3개 중 3개
    • Locate the white wire connected to the corner of the top of the motherboard.
    • Disconnect the wire by firmly grasping the metal connection with your fingers or tweezers and pulling up until it detaches.
    • Unthread the wire from the tape and move it off to the side using tweezers or your fingers.
    댓글 쓰기
  17. PlayStation 4 Slim Fan System Replacement: 17 단계, 이미지 3개 중 1개 PlayStation 4 Slim Fan System Replacement: 17 단계, 이미지 3개 중 2개 PlayStation 4 Slim Fan System Replacement: 17 단계, 이미지 3개 중 3개
    • Remove the connections by pulling out on the blue tabs with your fingers.
    • Flip up the black clip on the largest tab with your finger before removing it.
    • Remove this wire connection by firmly gripping the wire with your fingers and pulling it out.
    댓글 쓰기
  18. PlayStation 4 Slim Fan System Replacement: 18 단계, 이미지 3개 중 1개 PlayStation 4 Slim Fan System Replacement: 18 단계, 이미지 3개 중 2개 PlayStation 4 Slim Fan System Replacement: 18 단계, 이미지 3개 중 3개
    • Remove the metal plate by grabbing two sides of the plate and lifting up and away from yourself.
    • You may need to wiggle the plate a bit to get it loose before you lift it out.
    • Do not lose any of the black pads attached to the motherboard while performing this step.
    댓글 쓰기
  19. PlayStation 4 Slim Fan System Replacement: 19 단계, 이미지 3개 중 1개 PlayStation 4 Slim Fan System Replacement: 19 단계, 이미지 3개 중 2개 PlayStation 4 Slim Fan System Replacement: 19 단계, 이미지 3개 중 3개
    • Unscrew and remove the two 10.0mm screws (one silver and one black) using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Remove the small metal plate by grabbing it with your fingers and lifting up.
    댓글 쓰기
  20. PlayStation 4 Slim Fan System Replacement: 20 단계, 이미지 3개 중 1개 PlayStation 4 Slim Fan System Replacement: 20 단계, 이미지 3개 중 2개 PlayStation 4 Slim Fan System Replacement: 20 단계, 이미지 3개 중 3개
    • Remove this wire connection by firmly grasping it with tweezers and pulling out.
    • This might require a bit of force to disconnect, but be sure not to break any of the wires.
    댓글 쓰기
  21. PlayStation 4 Slim Fan System Replacement: 21 단계, 이미지 2개 중 1개 PlayStation 4 Slim Fan System Replacement: 21 단계, 이미지 2개 중 2개
    • Remove the motherboard by grabbing the edge of the board with one or two hands and pulling away and up.
    • You may need to wiggle the board a bit to get it loose before you remove it.
    댓글 쓰기
  22. PlayStation 4 Slim Fan System Replacement, Fan System: 22 단계, 이미지 2개 중 1개 PlayStation 4 Slim Fan System Replacement, Fan System: 22 단계, 이미지 2개 중 2개
    • Unscrew and remove the six 4.0mm screws using a PH00 screwdriver with a counter-clockwise motion.
    댓글 쓰기
  23. PlayStation 4 Slim Fan System Replacement: 23 단계, 이미지 2개 중 1개 PlayStation 4 Slim Fan System Replacement: 23 단계, 이미지 2개 중 2개
    • Remove the metal plate by grabbing the edges and lifting up with your hands.
    댓글 쓰기
  24. PlayStation 4 Slim Fan System Replacement: 24 단계, 이미지 2개 중 1개 PlayStation 4 Slim Fan System Replacement: 24 단계, 이미지 2개 중 2개
    • Unscrew and remove the two 40 mm screws using a PH00 screwdriver with a counter-clockwise motion.
    댓글 쓰기
  25. PlayStation 4 Slim Fan System Replacement: 25 단계, 이미지 2개 중 1개 PlayStation 4 Slim Fan System Replacement: 25 단계, 이미지 2개 중 2개
    • Remove the fan system by grabbing the edge of the top metal plate and lifting up with your hands.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 86명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Harry Koos
회원 가입일: 01/24/18
6,586 평판
안내서 2개를 작성함
Cal Poly, Team S19-G4, Livingston Winter 2018 Cal Poly, Team S19-G4, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S19G4
4 회원들
안내서 36개를 작성함
6가이드 댓글
Thank you so much for this guide! It was very helpful!
David Rodriguez - 답글 공유
Deine Schrauben großen machen gar kein Sinn du hast mehr verschiedene Schrauben als es gibt
Andre Hollmann - 답글 공유
My PS4 “Slim” is quite different internally than the one shown. But regardless, this guide is an excellent resource for us diy’ers. And don’t forget any parts when reassembling, like I did. Took four tries to get everything back where it belonged. And man, was it dusty in there! Regular cleaniings are a must.
Patrick Ogren - 답글 공유
My ps4 slim is different it has some extra parts, now I don’t know how to put it back, hahahahahhahaha
Lancelotte Fabros - 답글 공유
This guide gets you 90% of the way there. Some really important pieces are missing though, primarily:
- How you dont need to unplug the power supply cable from the motherboard, you can just unhook it from the plastic clips on the case.
- It never mentions cleaning the old Thermal Paste off the heatsink + cpu and replacing with a new dab.
Both of these are essential for a proper tear-down. If you dont replace the thermal paste, your PS4 is guaranteed to break down irreparably in the future. I had to know or discover them for myself. Please, please update this guide with that info.
Zoey Schlemper - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 61
지난 7일: 511
지난 30일: 2,325
전체 시간: 192,248
