주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation Vita Rear Panel Replacement
Brittany McCrigler
Brittany McCrigler2 다른 기여자
최종 수정일 2025년 7월 2일
20 분
조정
This guide takes you through the process of installing the rear panel. The rear panel houses the rear touch pad.
필요한 것
부품
도구
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
더보기...
  1. PlayStation Vita Rear Panel Replacement, Case Separation: 1 단계, 이미지 2개 중 1개 PlayStation Vita Rear Panel Replacement, Case Separation: 1 단계, 이미지 2개 중 2개
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Rear Panel Replacement: 2 단계, 이미지 3개 중 1개 PlayStation Vita Rear Panel Replacement: 2 단계, 이미지 3개 중 2개 PlayStation Vita Rear Panel Replacement: 2 단계, 이미지 3개 중 3개
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Rear Panel Replacement: 3 단계, 이미지 2개 중 1개 PlayStation Vita Rear Panel Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Rear Panel Replacement: 4 단계, 이미지 3개 중 1개 PlayStation Vita Rear Panel Replacement: 4 단계, 이미지 3개 중 2개 PlayStation Vita Rear Panel Replacement: 4 단계, 이미지 3개 중 3개
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Rear Panel Replacement: 5 단계, 이미지 2개 중 1개 PlayStation Vita Rear Panel Replacement: 5 단계, 이미지 2개 중 2개
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Rear Panel Replacement: 6 단계, 이미지 1개 중 1개
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Rear Panel Replacement: 7 단계, 이미지 1개 중 1개
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Rear Panel Replacement: 8 단계, 이미지 1개 중 1개
    • Separate the front and rear cases.
  9. PlayStation Vita Rear Panel Replacement, Battery: 9 단계, 이미지 2개 중 1개 PlayStation Vita Rear Panel Replacement, Battery: 9 단계, 이미지 2개 중 2개
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
  10. PlayStation Vita Rear Panel Replacement: 10 단계, 이미지 2개 중 1개 PlayStation Vita Rear Panel Replacement: 10 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
  11. PlayStation Vita Rear Panel Replacement: 11 단계, 이미지 3개 중 1개 PlayStation Vita Rear Panel Replacement: 11 단계, 이미지 3개 중 2개 PlayStation Vita Rear Panel Replacement: 11 단계, 이미지 3개 중 3개
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
  12. PlayStation Vita Rear Panel Replacement, Rear Panel: 12 단계, 이미지 3개 중 1개 PlayStation Vita Rear Panel Replacement, Rear Panel: 12 단계, 이미지 3개 중 2개 PlayStation Vita Rear Panel Replacement, Rear Panel: 12 단계, 이미지 3개 중 3개
    • Slide the spuder between the right speaker and the rear casing.
    • Using a spudger, gently peel up the right speaker from the light adhesive connecting it to casing.
    • Remove the right speaker.
  13. PlayStation Vita Rear Panel Replacement: 13 단계, 이미지 3개 중 1개 PlayStation Vita Rear Panel Replacement: 13 단계, 이미지 3개 중 2개 PlayStation Vita Rear Panel Replacement: 13 단계, 이미지 3개 중 3개
    • Slide the spudger between the left speaker and the rear casing.
    • Using a spudger, gently peel up the left speaker from the light adhesive connecting it to casing.
    • Remove the left speaker.
  14. PlayStation Vita Rear Panel Replacement: 14 단계, 이미지 1개 중 1개
    • The rear panel remains.
결론
다른 11명이 해당 안내서를 완성하였습니다.
향후 수리를 위한 준비
모두 쇼핑하기
작성자
2다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
90,331 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 23,278개를 작성함
5가이드 댓글
I really enjoyed Your article ! I'm about to replace the touch pad, i got a Vita recently but it has some Heavy scuffs. I've seen the back touch pad has adhesive attached on it. I bought a replacement On Ebay. I'm not sure if the replacement has adhesive with it. If it doesn't what would be your guys Thoughts on what i should use?
Daniel - 답글
lol you will need some kind of adhesive its called common sense if Sony use it you use it simple
TH3ORY -
I can't get pass Step 1. I can take out the bottom left screw of the rear touchpad but I can't take out the other 3. I bought a used Vita and there is a screw that turns but does not gout up. What should I do?
kken07655 - 답글
In the part that remains after complete disassembly, what are the two double pins at the top for, which later come into contact with the motherboard? I already have a new panel, but it has absolutely nothing except this one contact in the lower right part ...
Kamil Dębiec - 답글
Those are wifi antennas. You can get it out put it in to the new panel.
repairguy69 -
댓글 쓰기
조회 통계:
지난 24시간: 16
지난 7일: 116
지난 30일: 478
전체 시간: 36,857
