소개
This guide takes you through installing the speakers in the PlayStation Vita.
필요한 것
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Gently insert a spudger along the side of the speaker on the back casing assembly. Pry the speaker off the casing and remove it.
다른 3명이 해당 안내서를 완성하였습니다.
2 Comments
my ps vita 3G model get washed, i dismantle the console and both speakers to let it dry. 1 month later my vita woke up but now the speakers sound bad, is there a way to fix them?
