주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Polaroid PTAB7XC USB Port Replacement
필요한 것
    1. Polaroid PTAB7XC USB Port Replacement, USB Port: 1 단계, 이미지 2개 중 1개 Polaroid PTAB7XC USB Port Replacement, USB Port: 1 단계, 이미지 2개 중 2개
      • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver, turning the screws counterclockwise.
      • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
      댓글 쓰기
    2. Polaroid PTAB7XC USB Port Replacement: 2 단계, 이미지 2개 중 1개 Polaroid PTAB7XC USB Port Replacement: 2 단계, 이미지 2개 중 2개
      • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
      • Lift the device off of the case and flip over the device so that it sits screen side down.
      • The device is now free from the plastic casing.
      • The power and/or volume buttons may fall out at this point. There is no problem with this; however, be sure to remember to reinstall them when reassembling the device.
      댓글 쓰기
    3. Polaroid PTAB7XC USB Port Replacement: 3 단계, 이미지 3개 중 1개 Polaroid PTAB7XC USB Port Replacement: 3 단계, 이미지 3개 중 2개 Polaroid PTAB7XC USB Port Replacement: 3 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Desolder the following components from the motherboard.
      • Desolder from the motherboard the red wire that connects to the speaker unit.
      • Desolder from the motherboard the black wire that connects to the speaker unit.
      • Desolder from the motherboard the gray wire that runs along the edge of the device.
      • Desolder from the motherboard the red wire that connects to the battery unit.
      • Desolder from the motherboard the black wire that connects to the battery unit.
      • The motherboard will now be detached from any wires connecting to the device.
      • If any of the wires do not detach completely during the desoldering process, then gently pull them off using tweezers.
      댓글 쓰기
    4. Polaroid PTAB7XC USB Port Replacement: 4 단계, 이미지 3개 중 1개 Polaroid PTAB7XC USB Port Replacement: 4 단계, 이미지 3개 중 2개 Polaroid PTAB7XC USB Port Replacement: 4 단계, 이미지 3개 중 3개
      • Use tweezers to unstick the medium width yellow ribbon cable from the motherboard.
      • Use a small plastic opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
      • Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
      • Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
      • The motherboard and battery will now be detached from any ribbon cables connecting to the device.
      댓글 쓰기
    5. Polaroid PTAB7XC USB Port Replacement: 5 단계, 이미지 3개 중 1개 Polaroid PTAB7XC USB Port Replacement: 5 단계, 이미지 3개 중 2개 Polaroid PTAB7XC USB Port Replacement: 5 단계, 이미지 3개 중 3개
      • Use the PH000 screwdriver remove the four 5 mm screws along the bottom edge of the motherboard, turning the screws counterclockwise.
      • The motherboard is now detached from the device.
      댓글 쓰기
    6. Polaroid PTAB7XC USB Port Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the motherboard out of the device using your hands.
      • Set the motherboard down on a heat safe surface so that the gray side of the motherboard is face up.
      댓글 쓰기
    7. Polaroid PTAB7XC USB Port Replacement: 7 단계, 이미지 1개 중 1개
      • Desolder each side of the USB port where it is attached to the motherboard.
      • The USB port will now be loosened from the motherboard.
      댓글 쓰기
    8. Polaroid PTAB7XC USB Port Replacement: 8 단계, 이미지 1개 중 1개
      • Using tweezers, pull the USB port straight out from the motherboard without wiggling it up, down, or side to side.
      • Wiggling the port may break the small connectors that remain attached to the motherboard.
      • The USB port is now replaceable.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Meg Lybbert
회원 가입일: 10/08/15
649 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 27
전체 시간: 647
