주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Porter-Cable PCC710B Lever Assembly Replacement
필요한 것
    1. Porter-Cable PCC710B Lever Assembly Replacement, Lever assembly: 1 단계, 이미지 1개 중 1개
      • Place the tool on its side so the orange and white warning label barcodes are facing up.
      • The lever and battery base of the tool should point toward you.
      댓글 쓰기
    2. Porter-Cable PCC710B Lever Assembly Replacement: 2 단계, 이미지 3개 중 1개 Porter-Cable PCC710B Lever Assembly Replacement: 2 단계, 이미지 3개 중 2개 Porter-Cable PCC710B Lever Assembly Replacement: 2 단계, 이미지 3개 중 3개
      • Use a 5.5 mm nut driver to unscrew the Hex nut.
      • If the Hex nut is not unscrewing easily- you can use a 3 mm Hex head screwdriver to hold the other side of the screw still.
      댓글 쓰기
    3. Porter-Cable PCC710B Lever Assembly Replacement: 3 단계, 이미지 1개 중 1개
      • Flip the tool over and remove the black screw holding the tool together.
      • Get a good grip on the screw by using pliers to pull the screw out of the tool.
      댓글 쓰기
    4. Porter-Cable PCC710B Lever Assembly Replacement: 4 단계, 이미지 3개 중 1개 Porter-Cable PCC710B Lever Assembly Replacement: 4 단계, 이미지 3개 중 2개 Porter-Cable PCC710B Lever Assembly Replacement: 4 단계, 이미지 3개 중 3개
      • Pinch the lever with your fingers and pull it up and away from the tool. The lever pops right off! You can squeeze on the lever, and it will come off just as easily.
      • When replacing your new lever assembly, make sure the black torsion (the black staple-like hinge) is oriented correctly.
      댓글 쓰기
결론
To reassemble your device, follow instruction steps 3 to 1 in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Alex Zapata
회원 가입일: 09/19/22
665 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 20
전체 시간: 481
