주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Porter-Cable PCE211 Fan Replacement
필요한 것
    1. Porter-Cable PCE211 Fan Replacement, Gearcase: 1 단계, 이미지 2개 중 1개 Porter-Cable PCE211 Fan Replacement, Gearcase: 1 단계, 이미지 2개 중 2개
      • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
      댓글 쓰기
    2. Porter-Cable PCE211 Fan Replacement: 2 단계, 이미지 3개 중 1개 Porter-Cable PCE211 Fan Replacement: 2 단계, 이미지 3개 중 2개 Porter-Cable PCE211 Fan Replacement: 2 단계, 이미지 3개 중 3개
      • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
      • Be careful about any loose parts when removing the head.
      댓글 쓰기
    1. Porter-Cable PCE211 Fan Replacement, Anvil: 3 단계, 이미지 3개 중 1개 Porter-Cable PCE211 Fan Replacement, Anvil: 3 단계, 이미지 3개 중 2개 Porter-Cable PCE211 Fan Replacement, Anvil: 3 단계, 이미지 3개 중 3개
      • Firmly pull the to remove drill bit holder also known as the anvil.
      • Before replacing the anvil, lubricate the base for the best performance.
      댓글 쓰기
    1. Porter-Cable PCE211 Fan Replacement, Motor: 4 단계, 이미지 3개 중 1개 Porter-Cable PCE211 Fan Replacement, Motor: 4 단계, 이미지 3개 중 2개 Porter-Cable PCE211 Fan Replacement, Motor: 4 단계, 이미지 3개 중 3개
      • This section tends to get messy so it would be best to have a paper towel or microfiber towel handy.
      • Pull the motor out with your hands.
      댓글 쓰기
    2. Porter-Cable PCE211 Fan Replacement: 5 단계, 이미지 3개 중 1개 Porter-Cable PCE211 Fan Replacement: 5 단계, 이미지 3개 중 2개 Porter-Cable PCE211 Fan Replacement: 5 단계, 이미지 3개 중 3개
      • Wipe out the old grease with a towel. Use the appropriate motor grease for electric tools to lubricate the top area, base of the motor, and the space the motor sits.
      댓글 쓰기
    1. Porter-Cable PCE211 Fan Replacement, Rear Housing: 6 단계, 이미지 2개 중 1개 Porter-Cable PCE211 Fan Replacement, Rear Housing: 6 단계, 이미지 2개 중 2개
      • Remove the four 6 mm screws using a Phillips #2 screwdriver.
      • The screws are tight so you will need to use a bit of arm strength.
      댓글 쓰기
    2. Porter-Cable PCE211 Fan Replacement: 7 단계, 이미지 2개 중 1개 Porter-Cable PCE211 Fan Replacement: 7 단계, 이미지 2개 중 2개
      • Pull the rear housing off the back of the impact wrench.
      • Be careful when removing the rear case that loose parts don't get damaged.
      댓글 쓰기
    1. Porter-Cable PCE211 Fan Replacement, Grip: 8 단계, 이미지 2개 중 1개 Porter-Cable PCE211 Fan Replacement, Grip: 8 단계, 이미지 2개 중 2개
      • Using the Phillips #2 screwdriver, remove the three 8 mm screws from the grip of the impact wrench.
      댓글 쓰기
    2. Porter-Cable PCE211 Fan Replacement: 9 단계, 이미지 2개 중 1개 Porter-Cable PCE211 Fan Replacement: 9 단계, 이미지 2개 중 2개
      • Pull the grip from the body of the impact wrench.
      댓글 쓰기
    1. Porter-Cable PCE211 Fan Replacement, Fan: 10 단계, 이미지 2개 중 1개 Porter-Cable PCE211 Fan Replacement, Fan: 10 단계, 이미지 2개 중 2개
      • Lift the hammer block (which is attached to the fan) out of the case.
      • It is a little heavy so be careful when lifting it out.
      댓글 쓰기
    2. Porter-Cable PCE211 Fan Replacement: 11 단계, 이미지 2개 중 1개 Porter-Cable PCE211 Fan Replacement: 11 단계, 이미지 2개 중 2개
      • If you're doing maintenance and the fan isn't damage, use a microfiber cloth to clean the fan.
      • Wipe well until there's no residue or oil lubricant.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Layla Berry
회원 가입일: 09/19/22
678 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 28
전체 시간: 430
