소개
How to remove the processor from the logic board.
부품
부품은 필요하지 않습니다.
Pull on outer latch.
Lower door until it is level with your work surface.
Use the spudger to pry the clips horizontally off of the heat sink.
Fully remove the clips by lifting upwards.
Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
Remove processor by pulling vertically upwards.
거의 끝나갑니다!
결승점
다른 12명이 해당 안내서를 완성하였습니다.
