주요 콘텐츠로 건너뛰기
Power Mac G4 Quicksilver Hard Drive Replacement
Ryan Bylard
Ryan Bylard2 다른 기여자
최종 수정일 February 19, 2016
5 - 10 분
쉬움
Removing the hard drive of the Power Mac G4 Quicksilver for replacement.
필요한 것
도구
  1. Power Mac G4 Quicksilver Hard Drive Replacement, Opening the case: 1 단계, 이미지 1개 중 1개
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Power Mac G4 Quicksilver Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
    • The hard drive is located in the rear right corner of the case.
  5. Power Mac G4 Quicksilver Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Unplug the IDE ribbon cable. This is the wide flat grey cable.
  6. Power Mac G4 Quicksilver Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 Power Mac G4 Quicksilver Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the screw holding down the hard drive enclosure.
  7. Power Mac G4 Quicksilver Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the hard drive enclosure straight up and out.
    • Be carful not to pull the attached cable.
  8. Power Mac G4 Quicksilver Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the MOLEX connector.
    • This cable may be hard to remove. Grab the connector on either side as pictured and wiggle it back and forth to remove it.
  9. Power Mac G4 Quicksilver Hard Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the four screws holding the hard drive to the enclosure.
  10. Power Mac G4 Quicksilver Hard Drive Replacement: 10 단계, 이미지 1개 중 1개
    • Your hard drive is now free from the enclosure and is ready to be replaced.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ryan Bylard
회원 가입일: 01/20/10
1,325 평판
안내서 5개를 작성함
Cal Poly, Team 14-41, Regan Winter 2010 Cal Poly, Team 14-41, Regan Winter 2010 회원
CPSU-REGAN-W10S14G41
4 회원들
안내서 17개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 15,395
