PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Memory Door Replacement
3 분
조정
Remove your memory door to access the RAM chips.
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
