주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Protocol Dronium III AP Light Bulb Replacement
필요한 것
    1. Protocol Dronium III AP Light Bulb Replacement, Drone Battery Pack: 1 단계, 이미지 2개 중 1개 Protocol Dronium III AP Light Bulb Replacement, Drone Battery Pack: 1 단계, 이미지 2개 중 2개
      • Ensure the drone is powered off.
      • Press in and lift battery compartment cover.
      • A soft pry tool may be used for easier access.
      댓글 쓰기
    2. Protocol Dronium III AP Light Bulb Replacement: 2 단계, 이미지 1개 중 1개
      • Remove battery pack from body of drone.
      댓글 쓰기
    3. Protocol Dronium III AP Light Bulb Replacement: 3 단계, 이미지 2개 중 1개 Protocol Dronium III AP Light Bulb Replacement: 3 단계, 이미지 2개 중 2개
      • Disconnect white connectors between the battery pack and drone.
      댓글 쓰기
    1. Protocol Dronium III AP Light Bulb Replacement, L.E.D. Bulb(s): 4 단계, 이미지 1개 중 1개
      • Remove the eight (8) 5mm Philips screws attaching the motor arms to the body using a Philips J00 screwdriver.
      댓글 쓰기
    2. Protocol Dronium III AP Light Bulb Replacement: 5 단계, 이미지 2개 중 1개 Protocol Dronium III AP Light Bulb Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the six (6) 5mm Philips screws attaching the Body Cover to the Body of the drone using a Philips J00 screwdriver.
      • Remove the Body Cover.
      댓글 쓰기
    3. Protocol Dronium III AP Light Bulb Replacement: 6 단계, 이미지 2개 중 1개 Protocol Dronium III AP Light Bulb Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the two (2) 5mm Philips screws attaching the Motherboard to the body of the drone using a Philips J00 screwdriver.
      • Lift the Motherboard off the mounting position.
      • Do not pull hard on the Motherboard as solder connections are fragile.
      댓글 쓰기
    4. Protocol Dronium III AP Light Bulb Replacement: 7 단계, 이미지 2개 중 1개 Protocol Dronium III AP Light Bulb Replacement: 7 단계, 이미지 2개 중 2개
      • This step contains a tool that can present a potential burn hazard.
      • Prepare and warm up a soldering iron.
      • Position Motherboard so that the L.E.D. bulb solder joints are accessible.
      • Use the soldering iron to melt the solder joints.
      • For more detailed instructions on how to solder, visit out How to Solder and Desolder Connections guide.
      • Remove the L.E.D. bulb from the Motherboard
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Steven Mooers
회원 가입일: 10/18/17
401 평판
안내서 4개를 작성함
UW Tacoma, Team S1-G1, Rose Fall 2017 UW Tacoma, Team S1-G1, Rose Fall 2017 회원
UWT-ROSE-F17S1G1
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 21
전체 시간: 430
