주요 콘텐츠로 건너뛰기
Raleigh M20 Bicycle Rear Rack Replacement
Alyssa  Compania
Alyssa Compania7 다른 기여자
최종 수정일 January 20, 2025
10 - 15 분
쉬움
글머리 기호!
헷갈리는 텍스트
더 나은 이미지가 필요함
누락된 단계
This guide demonstrates how to remove and replace a rear rack from the Raleigh M20 bicycle. This requires the removal of the old rear rack before replacing the new rear rack.
필요한 것
부품
도구
  1. Raleigh M20 Bicycle Rear Rack Replacement, Bicycle Rear Rack: 1 단계, 이미지 2개 중 1개 Raleigh M20 Bicycle Rear Rack Replacement, Bicycle Rear Rack: 1 단계, 이미지 2개 중 2개
    • Make sure that the bike is upright and stable.
    • With both hands, place the rear rack on the rear wheel of the bike. Take note of where the rear rack will attach on the bike.
    • Make sure that the rear rack is fitted on the bike.
  2. Raleigh M20 Bicycle Rear Rack Replacement: 2 단계, 이미지 3개 중 1개 Raleigh M20 Bicycle Rear Rack Replacement: 2 단계, 이미지 3개 중 2개 Raleigh M20 Bicycle Rear Rack Replacement: 2 단계, 이미지 3개 중 3개
    • Place a screw to attach the rear rack to the frame of the tire.
    • Tighten the screw with a philips screwdriver by turning it in a clockwise direction.
    • Repeat the steps above on the other side of the bike.
  3. Raleigh M20 Bicycle Rear Rack Replacement: 3 단계, 이미지 3개 중 1개 Raleigh M20 Bicycle Rear Rack Replacement: 3 단계, 이미지 3개 중 2개 Raleigh M20 Bicycle Rear Rack Replacement: 3 단계, 이미지 3개 중 3개
    • Place the metal holder to be even with the bar sticking out of the rear rack.
    • Line up the holes. Place a bolt to attach them together.
    • Use a philips screwdriver to tighten the bolts.
    • Do this for both sides.
  4. Raleigh M20 Bicycle Rear Rack Replacement: 4 단계, 이미지 2개 중 1개 Raleigh M20 Bicycle Rear Rack Replacement: 4 단계, 이미지 2개 중 2개
    • Make sure that the rear rack is even. If it is not, redo the previous step.
    • Locate the screws on top of the rear rack. Tighten the screws using a philips screwdriver.
    • Once the screws are tightened, you are done.
결론
To detach the rear rack, follow the instructions of this guide in the reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Alyssa Compania
회원 가입일: 09/26/12
86 평판
안내서 1개를 작성함
Cal Poly, Team 7-49, Forte Fall 2012 Cal Poly, Team 7-49, Forte Fall 2012 회원
CPSU-FORTE-F12S7G49
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 1
전체 시간: 3,031
