Raleigh M20 Seat Cushion Replacement
This guide will give a step by step walkthrough of how to replace an old seat cushion with a new one.
Loosen the seat clamp by pulling the black lever away from the frame. Once this is done, simply rotate the lever counter-clockwise to loosen the seat.
Now you are ready to reassemble the seat with your new cushion. Just follow these same steps in the reverse order. Thanks for taking the time to use this guide!
다른 한 분이 해당 안내서를 완성하였습니다.
