주요 콘텐츠로 건너뛰기
Razer Blade 15" (2020) Battery Replacement
필요한 것
  1. Razer Blade 15" (2020) Battery Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Battery Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
    • Close the lid and flip your laptop over so the back cover faces up.
  2. Razer Blade 15" (2020) Battery Replacement, Unfasten the back cover: 2 단계, 이미지 1개 중 1개
    • Use a T5 Torx driver to remove the ten 3.7 mm-long screws securing the back cover.
  3. Razer Blade 15" (2020) Battery Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Battery Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Battery Replacement, Loosen the back cover: 3 단계, 이미지 3개 중 3개
    • The back cover is lightly secured to the motherboard by thermal pads. Depending on the age of your laptop, it may be easier or harder to remove.
    • Use a finger to pry up the right side of the back cover, starting at the Ethernet port cutout.
  4. Razer Blade 15" (2020) Battery Replacement, Remove the back cover: 4 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Battery Replacement, Remove the back cover: 4 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Battery Replacement, Remove the back cover: 4 단계, 이미지 3개 중 3개
    • Remove the back cover slowly, as to avoid tearing the thermal pads underneath.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads on its underside.
  5. Razer Blade 15" (2020) Battery Replacement, Soften the battery cable tape adhesive: 5 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Battery Replacement, Soften the battery cable tape adhesive: 5 단계, 이미지 2개 중 2개
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or cause a fire.
  6. Razer Blade 15" (2020) Battery Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Battery Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Battery Replacement, Remove the battery cable tape: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel and remove the battery cable tape.
  7. Razer Blade 15" (2020) Battery Replacement, Disconnect the battery: 7 단계, 이미지 2개 중 1개 Razer Blade 15" (2020) Battery Replacement, Disconnect the battery: 7 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  8. Razer Blade 15" (2020) Battery Replacement, Unfasten the battery: 8 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Battery Replacement, Unfasten the battery: 8 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Battery Replacement, Unfasten the battery: 8 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the five 5.3 mm screws securing the battery.
    • If stickers cover any of the screw heads, peel and remove them.
  9. Razer Blade 15" (2020) Battery Replacement, Remove the battery: 9 단계, 이미지 3개 중 1개 Razer Blade 15" (2020) Battery Replacement, Remove the battery: 9 단계, 이미지 3개 중 2개 Razer Blade 15" (2020) Battery Replacement, Remove the battery: 9 단계, 이미지 3개 중 3개
    • Remove the battery.
    • There's a delicate cable that might be adhered to the underside of the battery. If so, gently unstick it as you lift the battery.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
81,883 평판
안내서 455개를 작성함
Guide Team Guide Team 회원
Staff
9 회원들
안내서 11,421개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 28
지난 30일: 188
전체 시간: 3,712
