주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razer DeathAdder V2 Pro Battery Replacement
필요한 것
  1. Razer DeathAdder V2 Pro Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the mouse over so that the writing on the bottom faces up.
    댓글 쓰기
  2. Razer DeathAdder V2 Pro Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use a spudger to remove the three pads on the bottom of the mouse.
    댓글 쓰기
  3. Razer DeathAdder V2 Pro Battery Replacement: 3 단계, 이미지 2개 중 1개 Razer DeathAdder V2 Pro Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 1.2 mm screws from each corner of the mouse using a T6 Torx screwdriver.
    댓글 쓰기
  4. Razer DeathAdder V2 Pro Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Use a nylon spudger to pry the back cover away from the mouse.
    • Starting from the lower corner of the mouse is strongly recommended. Once the tool is in, slide it in between the top and the lower part of the mouse, and run it around the edge of the bottom cover until it pops out naturally.
    • Be cautious not to crack the top and the bottom covers of the mouse.
    댓글 쓰기
  5. Razer DeathAdder V2 Pro Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Detach the white connector with red wires gently from the side that connects the side buttons to the PCB.
    • Be careful not to pull too hard on the connector to avoid damaging the solder that connects to the PCB.
    댓글 쓰기
  6. Razer DeathAdder V2 Pro Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Make sure the PCB is disconnected as shown before pulling apart the two halves of the mouse.
    댓글 쓰기
  7. Razer DeathAdder V2 Pro Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Place both the top and bottom pieces of the mouse on their backs.
    댓글 쓰기
  8. Razer DeathAdder V2 Pro Battery Replacement: 8 단계, 이미지 2개 중 1개 Razer DeathAdder V2 Pro Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the three 1 mm screws that hold the battery to the circuit board using a Phillips #1 screwdriver.
    • Remove the battery from the mouse.
    댓글 쓰기
  9. Razer DeathAdder V2 Pro Battery Replacement: 9 단계, 이미지 2개 중 1개 Razer DeathAdder V2 Pro Battery Replacement: 9 단계, 이미지 2개 중 2개
    • the original battery and new battery instaled.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tatiana Nzeba
회원 가입일: 09/15/22
211 평판
안내서 1개를 작성함
9가이드 댓글
What Voltage and mAh is the battery?
Nicoolodion - 답글 공유
AliExpress ex. has the apropriate battery for this mouse.
It´s a battery with 1500mAh and 3,7V .
Claus Gärtner - 답글 공유
Are you referring to LOSONCOER?
pikimouse - 답글 공유
In case someone is in the same boat as me:
The original was a 3.7v 450mah battery.
I put in a 1500mah, 3.7v LOSONCOER battery, but also saw a 450 variant on AliExpress. The only problem with the losoncoer is that wasn't the same connector as the original, the losoncoer one was slimmer, so it was a bit odd and only worked with a lot of tinkering, but the guide is perfect!
Mārtiņš Būmanis - 답글 공유
Hi! Could you link a battery that works for this mouse? Are the 1500mah batteries just as big? The battery life is just 3 times as good? Do you know the name of the connector that the original uses?
Anton - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 58
지난 30일: 343
전체 시간: 13,025
