주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razer DeathAdder V3 Pro Encoder Replacement
필요한 것
  1. Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 1개 Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 2개 Razer DeathAdder V3 Pro Encoder Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 3개
    • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
    • Remove the three 7 mm screws using a Torx T6 screwdriver.
    댓글 쓰기
  2. Razer DeathAdder V3 Pro Encoder Replacement: 2 단계, 이미지 2개 중 1개 Razer DeathAdder V3 Pro Encoder Replacement: 2 단계, 이미지 2개 중 2개
    • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
    • Insert a spudger into the seam between the top and bottom shells.
    • Gently work around the edges unclipping the internal latches.
    • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
    • Carefully pull the shells apart to unplug the cable in the front.
    댓글 쓰기
  3. Razer DeathAdder V3 Pro Encoder Replacement: 3 단계, 이미지 2개 중 1개 Razer DeathAdder V3 Pro Encoder Replacement: 3 단계, 이미지 2개 중 2개
    • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
    댓글 쓰기
  4. Razer DeathAdder V3 Pro Encoder Replacement, Encoder: 4 단계, 이미지 1개 중 1개
    • Use a T6 Torx screwdriver to remove the 5mm screws securing the circuit board.
    • Unplug the battery from its connection on the right side.
    • Be careful not to break the two clips that hold the PCB at the front of the mouse.
    댓글 쓰기
  5. Razer DeathAdder V3 Pro Encoder Replacement: 5 단계, 이미지 1개 중 1개
    • At the front of the PCB next to the encoder, remove the switch held in place by clips by gently pulling it free.
    댓글 쓰기
  6. Razer DeathAdder V3 Pro Encoder Replacement: 6 단계, 이미지 2개 중 1개 Razer DeathAdder V3 Pro Encoder Replacement: 6 단계, 이미지 2개 중 2개
    • Wear eye protection.
    • Take care not to damage the PCB or any other components.
    • Use a pair of flush cutters to cut the legs of the encoder.
    • Desolder the legs of the 15 mm encoder on the underside of the PCB.
    • Remove the encoder.
    • Always solder in a well ventilated area.
    • Use a solder sucker to remove any excess solder.
    댓글 쓰기
  7. Razer DeathAdder V3 Pro Encoder Replacement: 7 단계, 이미지 1개 중 1개
    • Press the new 15 mm encoder into place
    • If the encoder does not fit properly, clean the old solder more thoroughly.
    • Solder the new 15 mm encoder into place.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Nicholas
회원 가입일: 09/24/25
453 평판
안내서 4개를 작성함
Texas Tech, Team 2-5, Johansen Fall 2025 Texas Tech, Team 2-5, Johansen Fall 2025 회원
TTU-JOHANSEN-F25S2G5
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 61
지난 30일: 270
전체 시간: 1,318
