주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razer DeathAdder V3 Pro USB-C Port Replacement
필요한 것
  1. Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 1개 Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 2개 Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: 1 단계, 이미지 3개 중 3개
    • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
    • Remove the three 7 mm screws using a Torx T6 screwdriver.
    댓글 쓰기
  2. Razer DeathAdder V3 Pro USB-C Port Replacement: 2 단계, 이미지 2개 중 1개 Razer DeathAdder V3 Pro USB-C Port Replacement: 2 단계, 이미지 2개 중 2개
    • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
    • Insert a spudger into the seam between the top and bottom shells.
    • Gently work around the edges unclipping the internal latches.
    • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
    • Carefully pull the shells apart to unplug the cable in the front.
    댓글 쓰기
  3. Razer DeathAdder V3 Pro USB-C Port Replacement: 3 단계, 이미지 2개 중 1개 Razer DeathAdder V3 Pro USB-C Port Replacement: 3 단계, 이미지 2개 중 2개
    • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
    댓글 쓰기
  4. Razer DeathAdder V3 Pro USB-C Port Replacement, USB-C Port: 4 단계, 이미지 1개 중 1개
    • Use a T6 Torx screwdriver to remove the 5mm screws from the circuit board.
    • Unplug the battery from its connection on the right.
    • Be careful not to break the two clips that hold the PCB at the front of the mouse.
    • Remove the circuit board from the mouse.
    댓글 쓰기
  5. Razer DeathAdder V3 Pro USB-C Port Replacement: 5 단계, 이미지 1개 중 1개
    • Always solder in a well ventilated area.
    • Apply solder to the four anchor points on the back corners and side of the USB-C port.
    • Once the solder has melted, use tweezers to remove the USB-C port.
    • Use a solder sucker to clean the area.
    댓글 쓰기
  6. Razer DeathAdder V3 Pro USB-C Port Replacement: 6 단계, 이미지 1개 중 1개
    • Apply flux, then apply solder to one anchor point to help line up the new USB-C port.
    • Once the USB-C port is aligned, apply flux to the other three anchor points and solder them.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Nicholas
회원 가입일: 09/24/25
453 평판
안내서 4개를 작성함
Texas Tech, Team 2-5, Johansen Fall 2025 Texas Tech, Team 2-5, Johansen Fall 2025 회원
TTU-JOHANSEN-F25S2G5
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 52
전체 시간: 308
