주요 콘텐츠로 건너뛰기
Razer Kraken Ear Pad Replacement
Elizabeth Scheiderer
Elizabeth Scheiderer5 다른 기여자
최종 수정일 December 18, 2023
5 분
매우 쉬움
This is a step-by-step, easy-to-follow guide on how to replace the ear pad(s) on your Razer Kraken headset. This guide can also be used for the Razer Kraken Kitty and Razer Kraken Gaming headsets.
You may need this guide if any of your ear pads are old, worn out, or if you are having volume issues with the audio output from your headphones.
There are no precautions, safety hazards, or prior repair skills you need before following this guide. It is quick, easy and safe.
  1. Razer Kraken Ear Pad Replacement, Ear Pad: 1 단계, 이미지 1개 중 1개
    • Grab the ear cushion between your thumb and forefinger.
    • Avoid snapping/tearing the ear cushion off the speaker.
  2. Razer Kraken Ear Pad Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the ear cushion away from the speaker, and slide it down to release the cushion from the plastic covering.
  3. Razer Kraken Ear Pad Replacement: 3 단계, 이미지 1개 중 1개
    • Continue sliding downwards around all edges of the ear cushion until the cushion is fully removed off the speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
회원 가입일: 09/15/22
100 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 27
지난 30일: 66
전체 시간: 1,149
