주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Razer Wolverine V3 Pro Battery Replacement
필요한 것
  1. Razer Wolverine V3 Pro Battery Replacement, Outer Shell: 1 단계, 이미지 3개 중 1개 Razer Wolverine V3 Pro Battery Replacement, Outer Shell: 1 단계, 이미지 3개 중 2개 Razer Wolverine V3 Pro Battery Replacement, Outer Shell: 1 단계, 이미지 3개 중 3개
    • Insert the end of a spudger or opening tool in the seam at the top of the controller.
    • Slide it around the edge to release the retaining clips.
    • Use the spudger to separate the front and back plastic outer shell of the controller.
    • Both panels should separate from the front of the bumpers.
    • This takes some patience to ensure the panels don’t crack.
    • Flip the controller so the bottom is facing up.
    • Use the spudger to separate the plastic covering on the hand grips.
    댓글 쓰기
  2. Razer Wolverine V3 Pro Battery Replacement: 2 단계, 이미지 2개 중 1개 Razer Wolverine V3 Pro Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use a JIS #0 screwdriver to remove ten 10 mm screws from the mid-frame.
    • Keep screws organized.
    댓글 쓰기
  3. Razer Wolverine V3 Pro Battery Replacement: 3 단계, 이미지 2개 중 1개 Razer Wolverine V3 Pro Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Use your hands to pry the back panel of the controller.
    • You now have access to the back buttons (2 on each side).
    댓글 쓰기
  4. Razer Wolverine V3 Pro Battery Replacement: 4 단계, 이미지 2개 중 1개 Razer Wolverine V3 Pro Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two JIS #0 scews securing the battery.
    댓글 쓰기
  5. Razer Wolverine V3 Pro Battery Replacement: 5 단계, 이미지 2개 중 1개 Razer Wolverine V3 Pro Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the actuators out of the way to access the screws beneath.
    • Use a Phillips #0 screwdriver to remove the two 6.9 mm screws under the voice coil actuators.
    댓글 쓰기
  6. Razer Wolverine V3 Pro Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the face cover from the controller.
    • The buttons may fall out in the process of removing the face cover. Be careful to not to lose them.
    • Now you have access to the internal components of the controller.
    댓글 쓰기
  7. Razer Wolverine V3 Pro Battery Replacement, Battery: 7 단계, 이미지 2개 중 1개 Razer Wolverine V3 Pro Battery Replacement, Battery: 7 단계, 이미지 2개 중 2개
    • The battery is the black rectangle shown in this figure.
    • Use a JIS #0 screwdriver to remove six screws.
    • One at each corner [6 mm].
    • One in the middle of the battery [3mm].
    • One right above the battery [4 mm].
    댓글 쓰기
  8. Razer Wolverine V3 Pro Battery Replacement: 8 단계, 이미지 3개 중 1개 Razer Wolverine V3 Pro Battery Replacement: 8 단계, 이미지 3개 중 2개 Razer Wolverine V3 Pro Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Use the spudger to gently disconnect the small circuit board on top of the battery cover.
    • Use the angled tweezers to pull the white JST connectors out of their sockets.
    댓글 쓰기
  9. Razer Wolverine V3 Pro Battery Replacement: 9 단계, 이미지 3개 중 1개 Razer Wolverine V3 Pro Battery Replacement: 9 단계, 이미지 3개 중 2개 Razer Wolverine V3 Pro Battery Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the battery from the controller.
    • The battery is glued to the black cover.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Malik Sharif
회원 가입일: 02/18/26
337 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 35
지난 30일: 108
전체 시간: 210
