주요 콘텐츠로 건너뛰기
Reassembling Braun EP 100 hair-trimmer  Trimmer head
cloclolulu
cloclolulu다른 한 명의 기여자
최종 수정일 July 11, 2024
5 - 10 분
조정
커뮤니티-기여 안내서
If ever you disassembled the trimmer head in order to clean it thoroughly, and then had trouble assembling it back again, here's a step-by-step guide of how to achieve it!
필요한 것
도구
  1. Reassembling Braun EP 100 hair-trimmer  Trimmer head, Trimmer head: 1 단계, 이미지 1개 중 1개
    • Pick the thin lubrication sheet and put it ontop of the base. Align the 3 holes.
  2. Reassembling Braun EP 100 hair-trimmer  Trimmer head: 2 단계, 이미지 1개 중 1개
    • Fit the first spring into the base (cast part). The ends have to be oriented to the bottom, as illustrated.
  3. Reassembling Braun EP 100 hair-trimmer  Trimmer head: 3 단계, 이미지 1개 중 1개
    • Turn around the assembled parts, and fit the short hair trimmer knives into the small pin (see arrow) of the cast piece.
  4. Reassembling Braun EP 100 hair-trimmer  Trimmer head: 4 단계, 이미지 1개 중 1개
    • Now insert the nail in between the spring ends and the small bracket. This will hold the ends and make it possible to further assemble the head.
  5. Reassembling Braun EP 100 hair-trimmer  Trimmer head: 5 단계, 이미지 1개 중 1개
    • Now you can fit the locking part into the two pins (see arrows). The spring ends should not be touched here - if yes, reposition the nail.
  6. Reassembling Braun EP 100 hair-trimmer  Trimmer head: 6 단계, 이미지 1개 중 1개
    • Now fit the base plate of step 1 onto the other parts, using the 3 T8 screws.
    • For the time being, do not tighten up the screws completely, just enough to hold all the parts together. This will allow you to gently lift the short hair trimmer with your finger - the knives will move downwards.
    • Now a step where you may need some extra patience: take the small spring, insert it into the groove of the short hair trimmer with the 2 ends, gently push it and insert the spring winding into the upper groove of the cast part.
  7. Reassembling Braun EP 100 hair-trimmer  Trimmer head: 7 단계, 이미지 2개 중 1개 Reassembling Braun EP 100 hair-trimmer  Trimmer head: 7 단계, 이미지 2개 중 2개
    • Now retract the nail from its position... (first picture)
    • ... and reinsert it one step higher (second picture), so that the nail pushes the spring ends above the plastic arms of the short hair trimmer.
  8. Reassembling Braun EP 100 hair-trimmer  Trimmer head: 8 단계, 이미지 1개 중 1개
    • Fit the wide hair trimmer into the assembled parts.
  9. Reassembling Braun EP 100 hair-trimmer  Trimmer head: 9 단계, 이미지 1개 중 1개
    • If necessary, put the spring ends behind the small guides in the wide hair trimmer part.
  10. Reassembling Braun EP 100 hair-trimmer  Trimmer head: 10 단계, 이미지 1개 중 1개
    • Fit the two oscillation arms into the 2 pins of the wide hair trimmer first, and by spreading them.
    • Then tilt them to the inside, that the small latches keep it in place.
    • Gently lift the other ends of the arms above the pin of the cast part. Careful: you may break the arms if you lift too hard!
  11. Reassembling Braun EP 100 hair-trimmer  Trimmer head: 11 단계, 이미지 1개 중 1개
    • Finally push the arms completely down the pin.
    • Well, that's it!
결론
To disassemble your device, follow these instructions in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
cloclolulu
회원 가입일: 12/19/10
319 평판
안내서 1개를 작성함
댓글 3개
The spring can be seen in the picture on step 11. I used narrow pliers to get it in it's place.
Jyrki Tikka - 답글
I think the oscillation arms inverted in the pic. The little "R" letter is, in effect, on the left mounted.
Another question: what's the right face of the lubrication sheet?
Federico Rocchi - 답글
Thank you some freak in my house broke the head bit, I managed to find all the pieces,
but couldnt figure out where the cross spring thing went. Appreciated!!
Marcos
Marcos - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 46
전체 시간: 13,747
