주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Redmi Note 9 Pro Rear Glass Replacement
필요한 것
  1. Redmi Note 9 Pro Rear Glass Replacement, Heat the rear glass: 1 단계, 이미지 1개 중 1개
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    댓글 쓰기
  2. Redmi Note 9 Pro Rear Glass Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Redmi Note 9 Pro Rear Glass Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Redmi Note 9 Pro Rear Glass Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    댓글 쓰기
  3. Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: 3 단계, 이미지 2개 중 1개 Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: 3 단계, 이미지 2개 중 2개
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    댓글 쓰기
  4. Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: 4 단계, 이미지 3개 중 1개 Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: 4 단계, 이미지 3개 중 2개 Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: 4 단계, 이미지 3개 중 3개
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    댓글 쓰기
  5. Redmi Note 9 Pro Rear Glass Replacement: 5 단계, 이미지 2개 중 1개 Redmi Note 9 Pro Rear Glass Replacement: 5 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    댓글 쓰기
  6. Redmi Note 9 Pro Rear Glass Replacement: 6 단계, 이미지 2개 중 1개 Redmi Note 9 Pro Rear Glass Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    댓글 쓰기
  7. Redmi Note 9 Pro Rear Glass Replacement, Remove the rear glass: 7 단계, 이미지 2개 중 1개 Redmi Note 9 Pro Rear Glass Replacement, Remove the rear glass: 7 단계, 이미지 2개 중 2개
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
259,250 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 25,949개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 24
지난 30일: 108
전체 시간: 8,971
