주요 콘텐츠로 건너뛰기
Remington S5500 Power Supply Cable Removal
Benjamin Yohe
Benjamin Yohe다른 한 명의 기여자
최종 수정일 September 20, 2018
10 분
쉬움
더 나은 소개글
Two tools required for the completion of this task include a PH1 screwdriver, and a prying tool.
All screws on this device are 10mm (0.393 in).
필요한 것
도구
  1. Remington S5500 Power Supply Cable Removal, Power Supply Cable: 1 단계, 이미지 2개 중 1개 Remington S5500 Power Supply Cable Removal, Power Supply Cable: 1 단계, 이미지 2개 중 2개
    • Place the prying tool in between the hair straightener and the aligning cap.
    • Push forwards on the prying tool to pop off the aligning cap.
  2. Remington S5500 Power Supply Cable Removal: 2 단계, 이미지 3개 중 1개 Remington S5500 Power Supply Cable Removal: 2 단계, 이미지 3개 중 2개 Remington S5500 Power Supply Cable Removal: 2 단계, 이미지 3개 중 3개
    • Remove the screws with the Phillips #1 screwdriver located underneath the aligning cap, one on each side of the straightener.
    • Use the prying tool to remove the aligning rods after the removal of the screws.
    • Gently separate each half of the hair straightener.
    • The spring located in the middle of this mechanism may pop out and can get lost very easily. Try to separate the two components slowly.
  3. Remington S5500 Power Supply Cable Removal: 3 단계, 이미지 2개 중 1개 Remington S5500 Power Supply Cable Removal: 3 단계, 이미지 2개 중 2개
    • After the hair straightener is separated, use a Phillips #1 screwdriver to remove the two screws located on the lower half of the straightener.
    • Use the prying tool to remove the hinge cover.
  4. Remington S5500 Power Supply Cable Removal: 4 단계, 이미지 2개 중 1개 Remington S5500 Power Supply Cable Removal: 4 단계, 이미지 2개 중 2개
    • Pull upwards while pulling outwards to disconnect the wire from the housing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Benjamin Yohe
회원 가입일: 07/11/18
303 평판
안내서 2개를 작성함
IUPUI, Team S3-G3, Wilson Summer 2018 IUPUI, Team S3-G3, Wilson Summer 2018 회원
IUPUI-WILSON-SU18S3G3
5 회원들
안내서 2개를 작성함
댓글 6개
Excelente trabajo! Muchas gracias por la información!
Ronnetto - 답글
is there a place where you can buy and replace the power cable, or the plug ?
alexandru popa - 답글
the slip ring plug that is ..
alexandru popa -
Hello,
from where did you get the spare power cord ?
Kes - 답글
part number would be helpful?
Steven Lamprell - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 41
전체 시간: 7,266
