주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Remove Stuck Disc from Samsung P241
필요한 것
    1. Remove Stuck Disc from Samsung P241, Top Case: 1 단계, 이미지 2개 중 1개 Remove Stuck Disc from Samsung P241, Top Case: 1 단계, 이미지 2개 중 2개
      • You will need to be near a power source for this guide.
      • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
      댓글 쓰기
    2. Remove Stuck Disc from Samsung P241: 2 단계, 이미지 2개 중 1개 Remove Stuck Disc from Samsung P241: 2 단계, 이미지 2개 중 2개
      • Pull the top cover towards you until you can lift it up and off.
      댓글 쓰기
    1. Remove Stuck Disc from Samsung P241, Remove Stuck Disc from Samsung P241: 3 단계, 이미지 1개 중 1개
      • After the top cover has been removed, locate the disc drive on the right hand side of the DVD player.
      댓글 쓰기
    2. Remove Stuck Disc from Samsung P241: 4 단계, 이미지 1개 중 1개
      • Locate the four rectangular holes in the top of the black plastic disc drive.
      댓글 쓰기
    3. Remove Stuck Disc from Samsung P241: 5 단계, 이미지 2개 중 1개 Remove Stuck Disc from Samsung P241: 5 단계, 이미지 2개 중 2개
      • You will now pry off the black plastic cover from the disc tray. Insert a flathead screwdriver into the slot indicated and press down while at the same time pulling the screwdriver towards the middle of the device. This will pop the plastic catch out to the side.
      댓글 쓰기
    4. Remove Stuck Disc from Samsung P241: 6 단계, 이미지 1개 중 1개
      • Without removing the first screwdriver, insert a second one into the hole indicated and do the same motion.
      • You can now lift up the right side of the cover. Don't pull up too far or you could break the clasps on the left side.
      댓글 쓰기
    5. Remove Stuck Disc from Samsung P241: 7 단계, 이미지 1개 중 1개
      • Now repeat this process, unclipping the catches on the other side.
      댓글 쓰기
    6. Remove Stuck Disc from Samsung P241: 8 단계, 이미지 3개 중 1개 Remove Stuck Disc from Samsung P241: 8 단계, 이미지 3개 중 2개 Remove Stuck Disc from Samsung P241: 8 단계, 이미지 3개 중 3개
      • You can now pop of the black plastic cover and see the exposed disc drive. If there is anything stuck inside that is jamming the drive, you can remove it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lawrence Smith
회원 가입일: 01/11/11
126 평판
안내서 1개를 작성함
Cal Poly, Team 14-7, Forte Winter 2011 Cal Poly, Team 14-7, Forte Winter 2011 회원
CPSU-FORTE-W11S14G7
5 회원들
안내서 81개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 30
지난 30일: 87
전체 시간: 4,659
