주요 콘텐츠로 건너뛰기
Removing Nishiki Aero II Front Wheel
Tobias Elder
Tobias Elder11 다른 기여자
최종 수정일 December 15, 2023
3 - 5 분
매우 쉬움
더 나은 이미지가 필요함
Use this guide to remove the front wheel from a Nishiki Aero II Road Bike or similar bikes that use a bolt-on axle, which is commonly found on older bikes or single speed city bikes. This guide is not for quick release or thru axles. Bolt-on axles are great for bikes that require simplicity and are better at stopping bike wheel theft because they take longer to remove compared to quick release axles. It is critical that this is done correctly; if not it can result in serious injury to the drop outs on the bike and to the rider if the wheel comes off due to improper installation.
Before using this guide make sure you have the correct size replacement 700c front wheel that has a bolt-on axle.
필요한 것
도구
  1. Removing Nishiki Aero II Front Wheel, Removing Road Bike Front Wheel: 1 단계, 이미지 1개 중 1개
    • Turn the bike upside down.
  2. Removing Nishiki Aero II Front Wheel: 2 단계, 이미지 1개 중 1개
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Removing Nishiki Aero II Front Wheel: 3 단계, 이미지 2개 중 1개 Removing Nishiki Aero II Front Wheel: 3 단계, 이미지 2개 중 2개
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Removing Nishiki Aero II Front Wheel: 4 단계, 이미지 1개 중 1개
    • Follow the previous steps for the opposite side.
  5. Removing Nishiki Aero II Front Wheel: 5 단계, 이미지 1개 중 1개
    • Lift the wheel up from the fork.
결론
작성자
11다른 기여자 명과 함께
Tobias Elder
회원 가입일: 04/25/13
113 평판
안내서 7개를 작성함
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G53
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 1,201
