Removing the Tower Fan Rotating Blade and Transformer
예상시간 없음
조정
액션 샷
더 나은 이미지가 필요함
더 많은 이미지가 필요함
세부 사항 누락
This guide will instruct you on how to remove the fan blade and transformer.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
In order to remove the fan blade pliers were used to remove the holding nut.
After the holding nut is loose, use the pliers to pull up to remove the nut.
거의 끝나갑니다!
결론
