주요 콘텐츠로 건너뛰기
Repairing Astro A50 Microphone
jfoster2
jfoster23 다른 기여자
최종 수정일 June 23, 2022
30 분
어려움
더 나은 소개글
필요한 것
도구
  1. Repairing Astro A50 Microphone, Repairing Astro A50 Microphone: 1 단계, 이미지 3개 중 1개 Repairing Astro A50 Microphone, Repairing Astro A50 Microphone: 1 단계, 이미지 3개 중 2개 Repairing Astro A50 Microphone, Repairing Astro A50 Microphone: 1 단계, 이미지 3개 중 3개
    • In order to replace the battery you must completely dissemble the ear piece with the mic. First remove the foam cushions from the ear piece. Do this by simply pulling the foam away from the ear piece. This will expose the 4 screws. Next Remove these 4 screws with a small Phillips head screwdriver.
  2. Repairing Astro A50 Microphone: 2 단계, 이미지 3개 중 1개 Repairing Astro A50 Microphone: 2 단계, 이미지 3개 중 2개 Repairing Astro A50 Microphone: 2 단계, 이미지 3개 중 3개
    • Once the black plastic cover is removed, proceed to remove the two marked visible screws. Next peel back the foam in the top left and right corners of the speaker (the foam is glued on so be careful when removing it). During reassembly this will need to be re glued. once the screws are exposed remove them with the same screw driver.
  3. Repairing Astro A50 Microphone: 3 단계, 이미지 2개 중 1개 Repairing Astro A50 Microphone: 3 단계, 이미지 2개 중 2개
    • Locate the mic port and see if a wire is no longer connected to it. To reconnect the wire you will need to solder the wire back to the mic port. If you need help soldering refer to the soldering guide here.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
jfoster2
회원 가입일: 10/22/15
213 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-5, Shastany Fall 2015 UMass Dartmouth, Team 2-5, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S2G5
4 회원들
안내서 10개를 작성함
댓글 7개
Hi thanks for youe guide but i have an issue . I have adtro a50 gen2 and the problem is with the mic it is not working at all and i opened the headset and i noticed that there is a timy green wire and it is not commected to any thing and when i flip the mic up and down it moves With the mic .i wish you could help me fix this problem
Ali aladwan - 답글
Same issue. That wire has broken loose from its original solder point, between the yellow and bare copper wires, along the bottom of the PCB. I am going to try to resolder it. The movement of the wire you mention is what I suspect causes the wire to break; it fatigues at the point where it is soldered from the flexing that results when you pivot the mic up and down, to mute and unmute.
Barry Elson - 답글
Did re said wrong end of fixing your problem. Right now my Astro A50 Gen 2 does not work in the down position. If I have the mic all the way ip
in the mute position and wiggle it just about and inch towards the talk I can get the mic to work so basically the mic looks to be at 11:00 o’clock position instead of the 8:00 o clock position it should be.
Should I take apart and look for the wire that fell loose.
kyle moulton -
How can you replace the blue wire/cable in the picture? And what is it for? Is it the cable for voice/game audio?
Omran Shohatee - 답글
Pritty sure the blue wire is for other ear speaker mic will be a single black wire
Terry Farrelly -
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 16
지난 30일: 67
전체 시간: 22,723
