주요 콘텐츠로 건너뛰기
Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator
Baschtl
Baschtl5 다른 기여자
최종 수정일 June 2, 2023
10 분
쉬움
커뮤니티-기여 안내서
A loose actuator screw makes the toothbrush useless as it prevents the engine to drive the actual toothbrush that is attached to the top of the device. However, repairing this failure can be achieved in just a few steps.
필요한 것
도구
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator, Prepare your tools.: 1 단계, 이미지 1개 중 1개
    • You will need two screwdrivers:
    • a 6.5mm flathead and
    • a small Phillips #1.
  2. Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator, Open the enclosure: 2 단계, 이미지 3개 중 1개 Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator, Open the enclosure: 2 단계, 이미지 3개 중 2개 Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator, Open the enclosure: 2 단계, 이미지 3개 중 3개
    • Have a look to an alternative opening procedure.
    • Take the flathead screwdriver.
    • Insert it into the slot located at the bottom of the handle and turn counterclockwise to release the bottom cap.
    • The second image shows the amount of turning needed to loosen the bottom cap.
    • Be careful with this as the plastic is not very solid. Deforming the material could result in issues when placing the device onto the charging station.
    • Hold the handle upside down, and push down on the shaft to release the internal components of the handle.
  3. Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator: 3 단계, 이미지 3개 중 1개 Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator: 3 단계, 이미지 3개 중 2개 Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator: 3 단계, 이미지 3개 중 3개
    • Carefully pull the internals out of the casing.
  4. Repairing Philips Sonicare HX6711 HealthyWhite 710 Actuator: 4 단계, 이미지 1개 중 1개
    • Take the small Phillips screwdriver.
    • Tighten the small screw that can be found near the top of the device internals
    • Pro tip: I experienced that the screw comes loose after just a few days if you do not take further actions.
    • Hence, unscrew the screw completely and put some superglue at the end of it. Then tighten it again. This prevents the screw to get loose due to the vibrations.
결론
To reassemble your device, follow these instructions in reverse order. Be sure not to insert the internals of the device twisted. Close the device by using the flathead screwdriver and imposing some pressure upon it. Finally, if the internals are in the enclosure close the device by turning the bottom cap clockwise.
다른 13명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Baschtl
회원 가입일: 12/02/12
1,608 평판
안내서 5개를 작성함
댓글 7개
thanks for that one - you rescued ours from a premature trip to the landfill :)
Olaf Draeger - 답글
Great guide. Thanks. I just tried doing this to mine but quickly found that the housing the screw goes into was broken completely in half. I wonder if I JB Weld would be strong enough to hold it together.
chiefbozz - 답글
Excellent guide; a simple fix saves $$ and waste. Thanks!!
David Sands - 답글
Thank you! It's realy help me!
Алексей Жерихин - 답글
Did the superglue tip work longterm? I'm just concerned if this approach fails then the glue residue is a mess along the threads. Send feedback!
Gideon - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 32
지난 30일: 159
전체 시간: 44,154
