주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repairing Quasar Microwave Sparking Inside
필요한 것
    1. Repairing Quasar Microwave Sparking Inside, Disassembling Quasar Microwave Outer Cover: 1 단계, 이미지 1개 중 1개
      • Disconnect the power supply cord from the outlet.
      댓글 쓰기
    2. Repairing Quasar Microwave Sparking Inside: 2 단계, 이미지 2개 중 1개 Repairing Quasar Microwave Sparking Inside: 2 단계, 이미지 2개 중 2개
      • Remove the eight screws holding the wood-patterned cover to the microwave frame.
      • The first four screws are located on either side of the microwave front.
      댓글 쓰기
    3. Repairing Quasar Microwave Sparking Inside: 3 단계, 이미지 2개 중 1개 Repairing Quasar Microwave Sparking Inside: 3 단계, 이미지 2개 중 2개
      • Remove the additional four screws securing the wood-paneled case to the microwave frame.
      댓글 쓰기
    4. Repairing Quasar Microwave Sparking Inside: 4 단계, 이미지 3개 중 1개 Repairing Quasar Microwave Sparking Inside: 4 단계, 이미지 3개 중 2개 Repairing Quasar Microwave Sparking Inside: 4 단계, 이미지 3개 중 3개
      • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
      • Lift the case upward slowly until the case is free of the microwave.
      댓글 쓰기
    1. Repairing Quasar Microwave Sparking Inside, Sparking: 5 단계, 이미지 1개 중 1개
      • First check to see if the interior of the microwave is dirty. Food or tin foil could be the reason that the microwave is sparking.
      • If the interior of the microwave is dirty, clean it. A spotless interior is recommended. The interior should look like the example in the picture.
      댓글 쓰기
    2. Repairing Quasar Microwave Sparking Inside: 6 단계, 이미지 1개 중 1개
      • If the microwave continues to spark after the interior has been cleaned, that could indicate that the diode may be broken. The diode is what attaches the capacitor to the back of the microwave.
      • A multimeter can be used to measure the resistance of the diode. The multimeter must be on the resistance setting or the diode check setting. If the diode reads zero in both directions, then it is broken.
      댓글 쓰기
    3. Repairing Quasar Microwave Sparking Inside: 7 단계, 이미지 1개 중 1개
      • Sparking inside of the microwave may also be the result of a broken or misaligned magnetron. If this is the case, it is recommended to take the microwave to a qualified professional or completely discarding the unit and purchasing a new one.
      • Fixing the magnetron without the aid of a qualified professional is NOT recommended. The magnetron is an emitter of microwave radiation and tampering with it may lead to serious injury or death.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Michael
회원 가입일: 09/26/12
237 평판
안내서 2개를 작성함
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G12
3 회원들
안내서 18개를 작성함
2가이드 댓글
Is the magnetron the failing component if you have this microwave or perhaps a 1983-1985 model quasar brand and the microwave doesn’t turn on after hitting “start”, a timer goes but no microwave heating is engaged?
Eric Ouyang - 답글 공유
This might be:
- A broken diode
- A faulty capacitor
- Or something else like a severed wire between the transformer and magnetron, a failing transformer or a failing magnetron.
Always be extra careful when opening a microwave oven as the capacitor may contain a deadly electric charge.
Unplug the microwave for at least 24 hours before opening it to reduce risks and use insulated tools and gloves.
Brendan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 41
전체 시간: 5,363
