주요 콘텐츠로 건너뛰기
Repairing Tritton Kunai Speaker Buzzing Noise
Essien Benjamin
Essien Benjamin5 다른 기여자
최종 수정일 May 17, 2022
예상시간 없음
조정
Learn how to stop the buzzing and bring back clear sound on your headset.
필요한 것
도구
  1. Repairing Tritton Kunai Speaker Buzzing Noise, Repairing Tritton Kunai Speaker Buzzing Noise: 1 단계, 이미지 2개 중 1개 Repairing Tritton Kunai Speaker Buzzing Noise, Repairing Tritton Kunai Speaker Buzzing Noise: 1 단계, 이미지 2개 중 2개
    • Remove the cushion of the speaker that the buzzing noise is occurring.
  2. Repairing Tritton Kunai Speaker Buzzing Noise: 2 단계, 이미지 3개 중 1개 Repairing Tritton Kunai Speaker Buzzing Noise: 2 단계, 이미지 3개 중 2개 Repairing Tritton Kunai Speaker Buzzing Noise: 2 단계, 이미지 3개 중 3개
    • Use the Philips PH00 screwdriver to unscrew the four screws located on the inner part of the rail adjustment.
  3. Repairing Tritton Kunai Speaker Buzzing Noise: 3 단계, 이미지 2개 중 1개 Repairing Tritton Kunai Speaker Buzzing Noise: 3 단계, 이미지 2개 중 2개
    • Remove the black metal bracket by unscrewing the two screws connecting it to the railing.
  4. Repairing Tritton Kunai Speaker Buzzing Noise: 4 단계, 이미지 2개 중 1개 Repairing Tritton Kunai Speaker Buzzing Noise: 4 단계, 이미지 2개 중 2개
    • Unscrew the screws in the locations shown to remove the speaker cover.
  5. Repairing Tritton Kunai Speaker Buzzing Noise: 5 단계, 이미지 1개 중 1개
    • Place the black cover to the side, near the rest of the setup.
  6. Repairing Tritton Kunai Speaker Buzzing Noise: 6 단계, 이미지 2개 중 1개 Repairing Tritton Kunai Speaker Buzzing Noise: 6 단계, 이미지 2개 중 2개
    • Observe the wire orientation: The red metal wire should be to the far left, while the green metal wire should be next to it, the skinny red rubber wire should be second to the right, and the thick red rubber wire should be to the far right. If any of the wires are out of place fasten them into their proper positions.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Essien Benjamin
회원 가입일: 03/19/15
166 평판
안내서 1개를 작성함
UMass Dartmouth, Team 3-3, Duarte Spring 2015 UMass Dartmouth, Team 3-3, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G3
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 10
전체 시간: 2,212
