주요 콘텐츠로 건너뛰기
Repairing the Stitching on an Insulated Jacket
필요한 것
  1. Repairing the Stitching on an Insulated Jacket, Repairing the Stitching on an Insulated Jacket: 1 단계, 이미지 3개 중 1개 Repairing the Stitching on an Insulated Jacket, Repairing the Stitching on an Insulated Jacket: 1 단계, 이미지 3개 중 2개 Repairing the Stitching on an Insulated Jacket, Repairing the Stitching on an Insulated Jacket: 1 단계, 이미지 3개 중 3개
  2. Repairing the Stitching on an Insulated Jacket: 2 단계, 이미지 2개 중 1개 Repairing the Stitching on an Insulated Jacket: 2 단계, 이미지 2개 중 2개
    • Set your sewing machine stitch length to about 3.
    • Clip the extra thread off of your jacket.
  3. Repairing the Stitching on an Insulated Jacket: 3 단계, 이미지 2개 중 1개 Repairing the Stitching on an Insulated Jacket: 3 단계, 이미지 2개 중 2개
    • Align the jacket in the sewing machine at a distance of roughly five stitches before the missing stitching.
    • Be sure that the jacket is unzipped and that you only have one layer of the jacket, including the lining, in the sewing machine. Sewing two layers together will sew the jacket shut.
  4. Repairing the Stitching on an Insulated Jacket: 4 단계, 이미지 3개 중 1개 Repairing the Stitching on an Insulated Jacket: 4 단계, 이미지 3개 중 2개 Repairing the Stitching on an Insulated Jacket: 4 단계, 이미지 3개 중 3개
    • Sink the needle, being sure that it aligns with the stitching.
    • Sew forward a few stitches and then backstitch to hold your stitches in place.
    • Sew along the holes where the stitching used to be.
  5. Repairing the Stitching on an Insulated Jacket: 5 단계, 이미지 3개 중 1개 Repairing the Stitching on an Insulated Jacket: 5 단계, 이미지 3개 중 2개 Repairing the Stitching on an Insulated Jacket: 5 단계, 이미지 3개 중 3개
    • Continue sewing until you overlap five of the remaining stitches.
    • Backstitch to hold your stitches in place.
    • Clip any threads to free the garment from the sewing machine.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
89,865 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,623개를 작성함
2 Guide Comments
Do you think you could demonstrate adding an elastic cuff to the nano-puff? I have one but the sleeves are just a hair too short.
Luke Cardoni - 답글
I got a new jacket recently and soon discovered loose stitching on the sleeve underarm.
On my precious jacket I didn’t want to use a sewing machine -sewing the two layers together- so I used a needle and the loose thread to secure the loose threads to the fabric.
This time I tried my grandmothers #12 crochet needle to crochet (knot) the threads to the secure stitches and pull the ends under.
Sue clark - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 21
지난 30일: 140
전체 시간: 20,889
