주요 콘텐츠로 건너뛰기
Rescue Your UGGs: A Guide to Removing Water Stains on UGGs
Lara Van Heerden
Lara Van Heerden다른 한 명의 기여자
최종 수정일 February 13, 2025
2 일
조정
커뮤니티-기여 안내서
Use this guide to restore water-stained UGG boots.
When exposed to rain or puddles, UGG boots may develop water stains on the sheepskin, making them look less appealing. Our walkthrough offers detailed instructions and the necessary materials to effectively remove these stains, emphasizing gentle techniques to protect the boots. Save your UGGs from permanent harm and the need for replacement by following this comprehensive guide.
Exercise caution throughout the restoration process for optimal results, and ensure the boots are kept out of direct sunlight when drying.
  1. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Brush off dirt: 1 단계, 이미지 2개 중 1개 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Brush off dirt: 1 단계, 이미지 2개 중 2개
    • Gently brush the exterior of the boots with a soft suede brush. 
  2. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Dampen boots: 2 단계, 이미지 2개 중 1개 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Dampen boots: 2 단계, 이미지 2개 중 2개
    • Use the sponge to lightly dampen the outer surface of your boots with cold water (do NOT soak as it will damage fabric).
  3. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Cleaning Boots: 3 단계, 이미지 2개 중 1개 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Cleaning Boots: 3 단계, 이미지 2개 중 2개
    • Apply a small amount of the sheepskin cleaner and conditioner on a wet sponge and gently rub the problem areas on the exterior of the UGG boots. ​ Note: Scrubbing vigorously can cause damage
  4. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Stuff for Shape: 4 단계, 이미지 2개 중 1개 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Stuff for Shape: 4 단계, 이미지 2개 중 2개
    • Stuff newspaper or paper towels into the boots to help maintain their shape. 
  5. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Air Dry: 5 단계, 이미지 1개 중 1개
    • Place the UGG boots in a dry and well-ventilated area away from direct sunlight to dry (Do not use heat to speed up the process).
  6. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Brush: 6 단계, 이미지 2개 중 1개 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Brush: 6 단계, 이미지 2개 중 2개
    • When the boots are dry gently brush the exterior with a soft suede brush.  
  7. Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Remove fillers: 7 단계, 이미지 3개 중 1개 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Remove fillers: 7 단계, 이미지 3개 중 2개 Rescue Your UGGs: A Guide to Removing Water Stains on UGGs, Remove fillers: 7 단계, 이미지 3개 중 3개
    • Remove the newspaper or paper towels from the boots.
결승점
작성자
1다른 기여자 명과 함께
Lara Van Heerden
회원 가입일: 11/27/23
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 36
지난 30일: 276
전체 시간: 2,589
