주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Retro-Bit Retro Duo Reset Button/Power Switch Replacement
필요한 것
  1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: 1 단계, 이미지 3개 중 1개 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: 1 단계, 이미지 3개 중 2개 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: 1 단계, 이미지 3개 중 3개
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one, or more, of the screws. Simply remove the it before the screws.
    • Flip the console on its feet and carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not completely remove the top case. There is a small circuit board--which houses two LEDs-- connected to the main circuit board.
    댓글 쓰기
  2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: 2 단계, 이미지 3개 중 1개 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: 2 단계, 이미지 3개 중 2개 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case.
    • This step allows easy button access and prevents accidental damage.
    댓글 쓰기
  3. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: 3 단계, 이미지 3개 중 1개 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: 3 단계, 이미지 3개 중 2개 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using your fingers (or precision tweezers), carefully pinch the button tabs and push through to the other side.
    • Make sure you pinch both tabs simultaneously, or the button will not pop out.
    댓글 쓰기
결론
If the problem persists after the buttons are replaced, it may be a circuit board issue. If so, please visit our guide for circuit board replacement at Retro-Bit Retro Duo Circuit Board Replacement
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Truong Vo
회원 가입일: 09/25/17
324 평판
안내서 3개를 작성함
USF Tampa, Team S4-G4, Eyestone Fall 2017 USF Tampa, Team S4-G4, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G4
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 50
전체 시간: 1,246
