주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RetroMini Miyoo Mini Plus Battery Replacement
필요한 것
  1. RetroMini Miyoo Mini Plus Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Lay the device face down on a flat surface.
    • You may want to lay the device on a towel or other soft surface to avoid scratching the screen.
    댓글 쓰기
  2. RetroMini Miyoo Mini Plus Battery Replacement: 2 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use your fingernail to push in the battery compartment tab.
    • Lift the cover up to expose the battery.
    댓글 쓰기
  3. RetroMini Miyoo Mini Plus Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Use an opening tool to gently lift the the battery from its compartment.
    • Gently pull the battery out and set the battery next to the system, with care not to strain the attached wire.
    댓글 쓰기
  4. RetroMini Miyoo Mini Plus Battery Replacement: 4 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Pinch the white battery connector and pull it directly out of its socket.
    • Completely remove the battery.
    댓글 쓰기
  5. RetroMini Miyoo Mini Plus Battery Replacement: 5 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Battery Replacement: 5 단계, 이미지 2개 중 2개
    • When you have the new battery, put the new battery wire into the connecter.
    • Place the battery back into the empty space with the wire at the bottom of the battery.
    댓글 쓰기
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kaden
회원 가입일: 08/28/24
599 평판
안내서 4개를 작성함
1가이드 댓글
Does anyone know where to get these batteries? Or perhaps the specs of the Miyoo Mini Plus battery such as dimensions (mine is a bit obese right now) and connector type?
Arend Hamming - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 21
지난 7일: 67
지난 30일: 310
전체 시간: 2,343
