주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
RetroMini Miyoo Mini Plus Screen Replacement
필요한 것
  1. RetroMini Miyoo Mini Plus Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Lay the device face down on a flat surface.
    • You may want to lay the device on a towel or other soft surface to avoid scratching the screen.
    댓글 쓰기
  2. RetroMini Miyoo Mini Plus Screen Replacement: 2 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Use your fingernail to push in the battery compartment tab.
    • Lift the cover up to expose the battery.
    댓글 쓰기
  3. RetroMini Miyoo Mini Plus Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Use an opening tool to gently lift the the battery from its compartment.
    • Gently pull the battery out and set the battery next to the system, with care not to strain the attached wire.
    댓글 쓰기
  4. RetroMini Miyoo Mini Plus Screen Replacement: 4 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Pinch the white battery connector and pull it directly out of its socket.
    • Completely remove the battery.
    댓글 쓰기
  5. RetroMini Miyoo Mini Plus Screen Replacement: 5 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Screen Replacement: 5 단계, 이미지 2개 중 2개
    • When you have the new battery, put the new battery wire into the connecter.
    • Place the battery back into the empty space with the wire at the bottom of the battery.
    댓글 쓰기
  6. RetroMini Miyoo Mini Plus Screen Replacement, Button: 6 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Screen Replacement, Button: 6 단계, 이미지 2개 중 2개
    • Remove the four screws securing the rear case with a Phillips screwdriver.
    • Remove the two Phillips screws inside the battery compartment.
    댓글 쓰기
  7. RetroMini Miyoo Mini Plus Screen Replacement: 7 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Insert an opening tool into the seam between the front and rear case.
    • Pry the front and rear case apart.
    댓글 쓰기
  8. RetroMini Miyoo Mini Plus Screen Replacement: 8 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Gently set the rear case aside.
    • Make sure you lift the black tab on the left side of the motherboard and gently remove the ribbon cable as to not damage it when removing the motherboard from the case.
    댓글 쓰기
  9. RetroMini Miyoo Mini Plus Screen Replacement: 9 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Use an opening tool to lift the motherboard from the chassis.
    댓글 쓰기
  10. RetroMini Miyoo Mini Plus Screen Replacement: 10 단계, 이미지 3개 중 1개 RetroMini Miyoo Mini Plus Screen Replacement: 10 단계, 이미지 3개 중 2개 RetroMini Miyoo Mini Plus Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Gently set the motherboard to the side.
    • Remove the rubber button gasket.
    댓글 쓰기
  11. RetroMini Miyoo Mini Plus Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the button(s) you want to replace.
    댓글 쓰기
  12. RetroMini Miyoo Mini Plus Screen Replacement, Screen: 12 단계, 이미지 1개 중 1개
    • Heat an iOpener according to the instructions here.
    • Rest the iOpener Gel Bag on the screen for a minute.
    • Alternatively, use a hair dryer to gently heat the screen to loosen the adhesive that secures it.
    댓글 쓰기
  13. RetroMini Miyoo Mini Plus Screen Replacement: 13 단계, 이미지 2개 중 1개 RetroMini Miyoo Mini Plus Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Gently apply pressure to the highlighted area on the front cover of the device.
    • While applying the pressure gently peel the screen off of the device.
    • Take care not to flex the screen. If the screen feels stubborn, apply more heat.
    댓글 쓰기
  14. RetroMini Miyoo Mini Plus Screen Replacement: 14 단계, 이미지 3개 중 1개 RetroMini Miyoo Mini Plus Screen Replacement: 14 단계, 이미지 3개 중 2개 RetroMini Miyoo Mini Plus Screen Replacement: 14 단계, 이미지 3개 중 3개
    • Set the new screen gently into the ridges (boxed in red) on the front of the backlit screen
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kaden
회원 가입일: 08/28/24
599 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 35
지난 30일: 211
전체 시간: 2,435
