주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Retroid Pocket 3 Battery Replacement
필요한 것
  1. Retroid Pocket 3 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    댓글 쓰기
  2. Retroid Pocket 3 Battery Replacement: 2 단계, 이미지 3개 중 1개 Retroid Pocket 3 Battery Replacement: 2 단계, 이미지 3개 중 2개 Retroid Pocket 3 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    댓글 쓰기
  3. Retroid Pocket 3 Battery Replacement: 3 단계, 이미지 2개 중 1개 Retroid Pocket 3 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    댓글 쓰기
  4. Retroid Pocket 3 Battery Replacement: 4 단계, 이미지 3개 중 1개 Retroid Pocket 3 Battery Replacement: 4 단계, 이미지 3개 중 2개 Retroid Pocket 3 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Cassidy Anderson
회원 가입일: 02/08/24
271 평판
안내서 2개를 작성함
1가이드 댓글
Hi, the battery of the Retroid Pocket 3 and 3Plus is customized for the manufacturing company, so it is not possible to find it in online stores and Retroid does not sell it as a spare part. Can you suggest a battery that has similar characteristics such as size, voltage and capacity? The battery is a 755565 3.8V and 4000mAh (for the Retroid 3 and 4500mAh for the 3Plus), can you suggest a 3.7V battery but with similar dimensions? Better a little smaller, otherwise it does not close inside the case. Thanks
Gianluca - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 36
지난 30일: 187
전체 시간: 4,750
