주요 콘텐츠로 건너뛰기
Revlon RVIR1008 Disassembly
Kelsea
Kelsea2 다른 기여자
최종 수정일 January 27, 2017
10 - 25 분
쉬움
잘못된 도구
더 나은 이미지가 필요함
커뮤니티-기여 안내서
Have you ever wondered what the inside of your curling iron looks like? Is your temperature wheel, swivel cord, or barrel clip broken? With this disassembly guide, you will be able to see the inner workings of a basic curling iron. This guide can also help you replace or fix parts of the curling iron that often wear out with daily use.
  1. Revlon RVIR1008 Disassembly, Revlon RVIR1008 Disassembly: 1 단계, 이미지 1개 중 1개
    • Be sure your curling iron is removed from the electrical outlet. Failure to unplug may result in electric shock and/or damage to the curling iron.
    • Place the curling iron on a clean, flat surface.
  2. Revlon RVIR1008 Disassembly, Remove the metal stand.: 2 단계, 이미지 1개 중 1개
    • Use your fingers to pull the ends of the stand away from the barrel. The metal stand should be easy to pry from the sides of the barrel.
  3. Revlon RVIR1008 Disassembly, Remove the barrel clip.: 3 단계, 이미지 2개 중 1개 Revlon RVIR1008 Disassembly, Remove the barrel clip.: 3 단계, 이미지 2개 중 2개
    • Using a 3mm Flathead screwdriver, slowly remove both screws from the sides of the barrel clip.
    • Take turns unscrewing each screw . The clip is operated by a tight metal spring. Completely removing one screw first makes it difficult to unscrew the second screw.
  4. Revlon RVIR1008 Disassembly, Remove the clip spring.: 4 단계, 이미지 2개 중 1개 Revlon RVIR1008 Disassembly, Remove the clip spring.: 4 단계, 이미지 2개 중 2개
    • Using two fingers, squeeze either side of the spring and slide the ends away from the barrel.
  5. Revlon RVIR1008 Disassembly, Remove the spring plate: 5 단계, 이미지 1개 중 1개
    • Using a 3mm Flathead Screwdriver, remove the screw holding the spring plate in place.
  6. Revlon RVIR1008 Disassembly, Remove the bottom of the handle.: 6 단계, 이미지 3개 중 1개 Revlon RVIR1008 Disassembly, Remove the bottom of the handle.: 6 단계, 이미지 3개 중 2개 Revlon RVIR1008 Disassembly, Remove the bottom of the handle.: 6 단계, 이미지 3개 중 3개
    • Using a 3mm Flathead Screwdriver, remove the 27mm screw on the left and the 15mm screw on the right.
    • When reassembling the curling iron, make sure to put the screws in their respective holes.
    • Once the screws are removed, the bottom plate easily comes off, exposing the inner components of the iron.
  7. Revlon RVIR1008 Disassembly, Remove the barrel shell.: 7 단계, 이미지 1개 중 1개
    • To remove the barrel, simply side the silver outer shell away from the inner heat transfer element.
    • The inner heat transfer element is attached to multiple AC power wires. When removing the barrel shell, make sure the inner heating element is not pulled away from the rest of the iron or the wires may tear off.
  8. Revlon RVIR1008 Disassembly, Remove the top of the handle.: 8 단계, 이미지 2개 중 1개 Revlon RVIR1008 Disassembly, Remove the top of the handle.: 8 단계, 이미지 2개 중 2개
    • Using your hands, slowly pull the inner components away from the top of the handle.
  9. Revlon RVIR1008 Disassembly, Remove the swivel cord.: 9 단계, 이미지 3개 중 1개 Revlon RVIR1008 Disassembly, Remove the swivel cord.: 9 단계, 이미지 3개 중 2개 Revlon RVIR1008 Disassembly, Remove the swivel cord.: 9 단계, 이미지 3개 중 3개
    • Using your hands, slowly pull the cord away from the socket. The cord should easily slide out of the socket.
  10. Revlon RVIR1008 Disassembly, Remove the temperature dials.: 10 단계, 이미지 3개 중 1개 Revlon RVIR1008 Disassembly, Remove the temperature dials.: 10 단계, 이미지 3개 중 2개 Revlon RVIR1008 Disassembly, Remove the temperature dials.: 10 단계, 이미지 3개 중 3개
    • Using two hands, grab each wheel and pull the temperature dials away from the circuit board.
  11. Revlon RVIR1008 Disassembly, You did it!: 11 단계, 이미지 1개 중 1개
    • You have successfully completed the disassembly! Follow these steps in reverse to reassemble your curling iron.
결승점
작성자
2다른 기여자 명과 함께
Kelsea
회원 가입일: 09/15/15
190 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 25
전체 시간: 3,510
