주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Rival 16131 Toaster Power Wire Repair
필요한 것
  1. Rival 16131 Toaster Power Wire Repair, Shell: 1 단계, 이미지 2개 중 1개 Rival 16131 Toaster Power Wire Repair, Shell: 1 단계, 이미지 2개 중 2개
    • Make sure the toaster is unplugged before dissembling.
    • Turn the toaster over and remove the rubber bumper feet.
    댓글 쓰기
  2. Rival 16131 Toaster Power Wire Repair: 2 단계, 이미지 2개 중 1개 Rival 16131 Toaster Power Wire Repair: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #2 screwdriver to remove four 12 mm screws at the base of the toaster shell.
    댓글 쓰기
  3. Rival 16131 Toaster Power Wire Repair: 3 단계, 이미지 3개 중 1개 Rival 16131 Toaster Power Wire Repair: 3 단계, 이미지 3개 중 2개 Rival 16131 Toaster Power Wire Repair: 3 단계, 이미지 3개 중 3개
    • With the dial facing you, push the toaster base up and away until the base is just over the lip of the shell. This will disconnect the browning dial from the rest of the toaster.
    • When reassembling the toaster, make sure that the back of the dial lines up with the slot, both in position and orientation (the dial and slot are not perfect circles - they have a notch).
    • The only object holding the shell onto the toaster now is the grey part of the lever.
    댓글 쓰기
  4. Rival 16131 Toaster Power Wire Repair: 4 단계, 이미지 1개 중 1개
    • Reach into the shell and grab the back white part of the lever.
    • Hold the grey lever with both your index finger and middle finger. Next, pull it.
    • Pulling too hard will break the mechanism that holds the grey handle onto the white lever.
    • Remove the shell.
    댓글 쓰기
  5. Rival 16131 Toaster Power Wire Repair, Rival 16131 Toaster Power Wire Repair: 5 단계, 이미지 2개 중 1개 Rival 16131 Toaster Power Wire Repair, Rival 16131 Toaster Power Wire Repair: 5 단계, 이미지 2개 중 2개
    • The power wire connects to the toaster in the area highlighted.
    • To free the wire, unscrew the two .5 inch screws, and remove the white brace.
    댓글 쓰기
  6. Rival 16131 Toaster Power Wire Repair: 6 단계, 이미지 1개 중 1개
    • To solder the the wire, the circuit board has to be released.
    • To do this, unscrew the .5 inch screw located in the middle of the board.
    • Slowly lift the board up off the toaster, making sure that the red pegs that hold the board in place do not break.
    댓글 쓰기
  7. Rival 16131 Toaster Power Wire Repair: 7 단계, 이미지 1개 중 1개
    • To reattach the wire, follow this solder guide.
    • Solder Guide
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Grant Haug
회원 가입일: 09/26/12
148 평판
안내서 4개를 작성함
Cal Poly, Team 2-8, Propen Fall 2012 Cal Poly, Team 2-8, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G8
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 37
전체 시간: 2,515
