주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Roborock S5 Laser Distance Sensor Motor Replacement
필요한 것
    1. Roborock S5 Laser Distance Sensor Motor Replacement, Laser Distance Sensor Motor: 1 단계, 이미지 3개 중 1개 Roborock S5 Laser Distance Sensor Motor Replacement, Laser Distance Sensor Motor: 1 단계, 이미지 3개 중 2개 Roborock S5 Laser Distance Sensor Motor Replacement, Laser Distance Sensor Motor: 1 단계, 이미지 3개 중 3개
      • Power down your Roborock S5.
      • Place it on a flat work surface with the power buttons facing toward you.
      • Use an opening tool to carefully pry under the section of the top panel with the buttons.
      • Gently pull upward to snap the panel off the top of the vacuum. It is secured in place by five snaps that you will need to release to remove the panel.
      • This can take some force, and the snaps can be quite loud. Be careful not to break the panel.
      댓글 쓰기
    2. Roborock S5 Laser Distance Sensor Motor Replacement: 2 단계, 이미지 3개 중 1개 Roborock S5 Laser Distance Sensor Motor Replacement: 2 단계, 이미지 3개 중 2개 Roborock S5 Laser Distance Sensor Motor Replacement: 2 단계, 이미지 3개 중 3개
      • Use a Phillips #2 screwdriver to remove the six 9 mm screws securing the other half of the top panel that covers the dust bin.
      • Remove the two hinge covers to free the other top panel.
      • Gently lift the other half of the top panel off of the robot vacuum.
      댓글 쓰기
    3. Roborock S5 Laser Distance Sensor Motor Replacement: 3 단계, 이미지 2개 중 1개 Roborock S5 Laser Distance Sensor Motor Replacement: 3 단계, 이미지 2개 중 2개
      • Use a spudger to pry off the rubber stoppers covering the three 12 mm screws that secure the Laser Distance Sensor housing cover.
      댓글 쓰기
    4. Roborock S5 Laser Distance Sensor Motor Replacement: 4 단계, 이미지 3개 중 1개 Roborock S5 Laser Distance Sensor Motor Replacement: 4 단계, 이미지 3개 중 2개 Roborock S5 Laser Distance Sensor Motor Replacement: 4 단계, 이미지 3개 중 3개
      • Use a Phillips #2 screwdriver to remove the three 12 mm screws holding the Laser Distance Sensor housing cover in place.
      • Use the same Phillips #2 screwdriver to remove the two 9 mm screws securing the Laser Distance Sensor housing cover.
      • Gently lift the cover off of the sensor.
      댓글 쓰기
    5. Roborock S5 Laser Distance Sensor Motor Replacement: 5 단계, 이미지 3개 중 1개 Roborock S5 Laser Distance Sensor Motor Replacement: 5 단계, 이미지 3개 중 2개 Roborock S5 Laser Distance Sensor Motor Replacement: 5 단계, 이미지 3개 중 3개
      • Use a Phillips #2 screwdriver to remove the four 9 mm screws holding the Laser Distance Sensor in place.
      • Gently lift it out of the robot vacuum.
      댓글 쓰기
    6. Roborock S5 Laser Distance Sensor Motor Replacement: 6 단계, 이미지 2개 중 1개 Roborock S5 Laser Distance Sensor Motor Replacement: 6 단계, 이미지 2개 중 2개
      • Turn the Laser Distance Sensor over so the backside is facing up.
      • Squeeze the tab against the connector, and pull the connector straight up from the socket to disconnect the power cable.
      댓글 쓰기
    7. Roborock S5 Laser Distance Sensor Motor Replacement: 7 단계, 이미지 3개 중 1개 Roborock S5 Laser Distance Sensor Motor Replacement: 7 단계, 이미지 3개 중 2개 Roborock S5 Laser Distance Sensor Motor Replacement: 7 단계, 이미지 3개 중 3개
      • Turn the Laser Distance Sensor housing back over.
      • Use a spudger to detach the plastic cord from the motor that connects it to the laser.
      • Use a Phillips #1 screwdriver to remove the two 4 mm screws attaching the motor to the housing.
      댓글 쓰기
    8. Roborock S5 Laser Distance Sensor Motor Replacement: 8 단계, 이미지 2개 중 1개 Roborock S5 Laser Distance Sensor Motor Replacement: 8 단계, 이미지 2개 중 2개
      • Slide the orange gear out of the housing to remove it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jacob Searcy
회원 가입일: 09/13/23
992 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 56
지난 30일: 197
전체 시간: 5,850
